Nexux 5596-UP "show hardware internal" command problem
Hi all,
I have a problem with one of our Nexus 5596. When I execute the following command on module 1 for any fc port, the switch displays an error:
show hardware internal fc-mac 1 port <fc_port_ID> port-event
switch-n5k-2# sh hardware internal fc-mac 1 port 43 port-event
gat_fcp_cli_port_port_event: dev_debug() returned error, errno = 22, rc = -1
switch-n5k-2# sh hardware internal fc-mac 1 port 44 link-event
gat_fcp_cli_port_link_event: dev_debug() returned error, errno = 22, rc = -1
The NX-OS version is: 5.1(3)N2(1b) and ports conecct to MDS-9000 and Servers.
Has someone else this problem?
Thanks in advance!
2 Accepted Solutions
Hello Iker,
Yes you are right the 96 have 48 fixed ports.
But in my 5548 it is 32 and i have the same error if i make the show command on a non exsiting port.
as shown up in my first reply.
If you have 7 identical N5596UP and you do not have the problem on others i would investergaate that.
Do you run the same NX-OS on them and are tey configured right?
If that is the case i would open a case with TAC I would also check that the NX-OS you are running has not been revoked.
My setup is a testlab so not en real production by my carmelusd task takes less than 1 % and the highes take about 6% CPU
sh processes cpu sort | include carme
3147     86117625  116934966    736    0.9%  carmelusd
Best regards,
Christian Hald
We are affected by this bug CSCu27720 (https://tools.cisco.com/bugsearch/bug/CSCuj27720) using NX-OS version 5.1(3)N2(1c).
Thanks for the info.
Best Regards.
6 Replies 6
chald
Hello Iker,
I have only the same problem if I issue the same command on a non existing port.
Remember how the 5596 is build you have 32 ports in slot 1 and then slot 2, 3 and 4. with each 16 ports
So it is only a cosmetic bug that you can issue it and if you list your interface with a show interface brief you can see it.
running code 5.2(1)N1(4)
N5KSW1# sh hardware internal fc-mac 1 port 32 port-event
MMDDYY HHMMSS usecs Event Current State
- - IPS_DOWN
TL-N85R5-N5K# sh hardware internal fc-mac 2 port 1 port-event
-                            -                               IPS_LINK_UP
082813 111939 841857 (0000)  E_IPS_LINK_INIT_SUC             IPS_LINK_INIT
082813 111939 841843 (0001)  E_IPS_IDLE                      IPS_LINK_INIT
082813 111939 838663 (0000)  E_IPS_LR                        IPS_LINK_INIT
082813 111939 832533 (0001)  E_IPS_TMO                       IPS_LINK_INIT
082813 111939 822555 (0000)  E_IPS_LINK_INIT                 IPS_SPEED
- - IPS_DOWN
N5KSW1# sh hardware internal fc-mac 1 port 33 port-event
N5KSW1# sh hardware internal fc-mac 1 port ?
<1-48> 1 based port number
N5KSW1# sh int brie
Interface  Vsan   Admin  Admin   Status          SFP    Oper  Oper   Port
                  Mode   Trunk                          Mode  Speed  Channel
                         Mode                                 (Gbps)
fc2/1      790    auto   off     up               swl    F       4    --
fc2/2      790    auto   off     notConnected     swl    --           --
fc2/3      790    auto   on      up               swl    F       8    --
fc2/4      790    auto   on      up               swl    F       8    --
fc2/5      1      auto   on      sfpAbsent        --     --           --
fc2/6      1      auto   on      sfpAbsent        --     --           --
fc2/7      1      auto   on      sfpAbsent        --     --           --
fc2/8      1      auto   on      sfpAbsent        --     --           --
fc2/9      1      auto   on      sfpAbsent        --     --           --
fc2/10     1      auto   on      sfpAbsent        --     --           --
fc2/11     1      auto   on      sfpAbsent        --     --           --
fc2/12     1      auto   on      sfpAbsent        --     --           --
fc2/13     1      auto   on      sfpAbsent        --     --           --
fc2/14     1      auto   on      sfpAbsent        --     --           --
fc2/15     1      auto   on      sfpAbsent        --     --           --
fc2/16     1      auto   on      sfpAbsent        --     --           --
Ethernet      VLAN    Type Mode   Status  Reason                   Speed     Port
Interface        Ch #
Eth1/1        701     eth  trunk  up      none                        10G(D) 1
Eth1/2        701     eth  trunk  up      none                        10G(D) 3
Eth1/3        701     eth  trunk  up      none                       1000(D) 2
Eth1/4        701     eth  trunk  up      none                       1000(D) 2
Eth1/5        1       eth  access down    SFP not inserted            10G(D) --
Eth1/6        1       eth  access down    SFP not inserted            10G(D) --
Eth1/7        1       eth  trunk  up      none                        10G(D) --
Eth1/8        1       eth  access down    SFP not inserted            10G(D) --
Eth1/9        1       eth  trunk  up      none                        10G(D) --
Eth1/10       1       eth  trunk  up      none                        10G(D) --
Eth1/11       1       eth  access down    SFP not inserted            10G(D) --
Eth1/12       1       eth  access down    SFP not inserted            10G(D) --
Eth1/13       1       eth  access down    SFP not inserted            10G(D) --
Eth1/14       1       eth  access down    SFP not inserted            10G(D) --
Eth1/15       701     eth  trunk  up      none                        10G(D) 1
Eth1/16       1       eth  access down    Link not connected          10G(D) --
Eth1/17       1       eth  access down    SFP not inserted            10G(D) --
Eth1/18       1       eth  access down    SFP not inserted            10G(D) --
Eth1/19       1       eth  access down    SFP not inserted            10G(D) --
Eth1/20       1       eth  access down    SFP not inserted            10G(D) --
Eth1/21       1       eth  access down    SFP not inserted            10G(D) --
Eth1/22       1       eth  access down    SFP not inserted            10G(D) --
Eth1/23       1       eth  access down    SFP not inserted            10G(D) --
Eth1/24       1       eth  access down    SFP not inserted            10G(D) --
Eth1/25       1       eth  access down    SFP not inserted            10G(D) --
Eth1/26       1       eth  access down    SFP not inserted            10G(D) --
Eth1/27       1       eth  access down    SFP not inserted            10G(D) --
Eth1/28       1       eth  access down    SFP not inserted            10G(D) --
Eth1/29       1       eth  access down    SFP not inserted            10G(D) --
Eth1/30       1       eth  access down    SFP not inserted            10G(D) --
Eth1/31       1       eth  trunk  down    Link not connected          10G(D) --
Eth1/32       1       eth  trunk  up      none                        10G(D) --
Port-channel VLAN    Type Mode   Status  Reason                    Speed   Protocol
Interface
Po1          701     eth  trunk  up      none                       a-10G(D)  lacp
Po2          701     eth  trunk  up      none                      a-1000(D)  lacp
Po3          701     eth  trunk  up      none                       a-10G(D)  lacp
Port   VRF          Status IP Address                              Speed    MTU
mgmt0  --           up     192.168.124.140                         1000     1500
Interface  Vsan   Admin  Admin   Status      Bind                 Oper    Oper
                  Mode   Trunk               Info                 Mode    Speed
                         Mode                                            (Gbps)
vfc1       1      F     on     trunking    port-channel1            TF   auto
vfc9       790    F     on     trunking    Ethernet1/9              TF   auto
vfc10      790    F     on     trunking    Ethernet1/10             TF   auto
vfc131     790    F     on     errDisabled Ethernet1/31             --
vfc132     790    F     on     trunking    Ethernet1/32             TF   auto
vfc790     790    F     on     trunking    Ethernet1/7              TF   auto
N5KSW1# sh hardware internal fc-mac 2 port 1 port-event
-                            -                               IPS_LINK_UP
Hello Chald,
first of all, thank you for your interest and your response, but you are wrong. The Nexus 5596-UP have 48 ports in module 1, and 3 expansion slots for modules 2, 3 and 4.
The problem we have is that fc1/4x ports exist, and the error occurs with all the ports in module 1.
Moreover, we have 7 Nexus 5596 more in our enviroment, wit same configuration, and don't have these events.
Could it be a bug? Maybe, but I'm worried because "carmel" process has a consumption about 50% of the CPU.
Any idea is appreciated.
Thank you very much!
Regards.
sw-cpd-mm-n5k-2# show process cpu sort
PID    Runtime(ms)  Invoked   uSecs  1Sec    Process
3030    817808748  412111137   1984   46.3%  carmelusd
switch-n5k-2# show hardware internal fc-mac 1  port 36 statistics
gat_fcp_cli_port_stats: dev_debug() returned error, errno = 22, rc = -1
switch-mm-n5k-2# show hardware internal fc-mac 1  port 37 statistics
Hello Iker,
Best regards,
Christian Hald
Hello Chald,
thank you very much for all.
Finally, we'll have to open  a TAC case.
Best Regards!
After opening a case with the Cisco TAC, they said us that we were affected by the following bug : CSCu27720.
The workaround to solve the problem was to reload the Nexus 5596UP switch.
Best Regards.
