NPIV error
tpahuja
Level 3
Level 3
Folks,
           I receive the following error when performing npiv on a MDS  9214 running  5.0(4d).
2013 Feb 14 15:18:53 switch %FLOGI-1-MSG_NPIV_NOT_SUPPORTED_WITH_TRUNKING: %$VSAN
100%$ [VSAN 100, Interface port-channel 2: mode[TF]] NPIV not supported - on this
platform, NPIV is not supported on trunking interfaces
Is this a hardware limitation or code limitation or not supported. Help would be highly appreciated.
Daniel Laden
Level 8
Level 8
It is a hardware limitation.
http://www.cisco.com/en/US/docs/switches/datacenter/mds9000/sw/5_2/configuration/guides/int/nx-os/pc.html
If  a Cisco MDS 9124 or 9134 switch is used as a core switch, only a  nontrunking F PortChannel is supported. Trunking is not supported on  this platform when NPIV enabled.
Thank You,
Dan Laden
Cisco PDI Data Center
Want to know more about how PDI can assist you?
http://www.youtube.com/watch?v=4BebSCuxcQU&list=PL88EB353557455BD7
http://www.cisco.com/go/pdihelpdesk
