5548UP VSAN Flogi Info
jlgjr
We are working with a  Nexus 5548UP connected to a EMC VNX5500 and four Dell R610 servers
We created VSAN 332 and VLAN 330
Here is the config.
class-map type qos class-fcoe
class-map type queuing class-fcoe
  match qos-group 1
class-map type queuing class-all-flood
  match qos-group 2
class-map type queuing class-ip-multicast
  match qos-group 2
class-map type network-qos class-fcoe
  match qos-group 1
class-map type network-qos class-all-flood
  match qos-group 2
class-map type network-qos class-ip-multicast
  match qos-group 2
system qos
  service-policy type qos input fcoe-default-in-policy
  service-policy type queuing input fcoe-default-in-policy
  service-policy type queuing output fcoe-default-out-policy
  service-policy type network-qos fcoe-default-nq-policy
slot 1
  port 1-32 type ethernet
vlan 330
  fcoe vsan 332
vsan database
  vsan 332
fcdomain fcid database
  vsan 332 wwn 50:06:01:69:3e:e4:00:d6 fcid 0x320000 dynamic
  vsan 332 wwn 50:06:01:61:3e:e4:00:d6 fcid 0x320001 dynamic
  vsan 332 wwn 21:00:00:c0:dd:1a:69:c7 fcid 0x320002 dynamic
  vsan 332 wwn 21:00:00:c0:dd:1a:6a:4f fcid 0x320003 dynamic
  vsan 332 wwn 21:00:00:c0:dd:1a:68:07 fcid 0x320004 dynamic
  vsan 332 wwn 21:00:00:c0:dd:1a:67:db fcid 0x320005 dynamic
interface vfc17
  bind interface Ethernet1/17
  switchport trunk allowed vsan 332
  switchport description HS-XEN-1
  no shutdown
interface vfc18
  bind interface Ethernet1/18
  switchport description HS-XEN-2
  no shutdown
interface vfc19
  bind interface Ethernet1/19
  switchport description HS-XEN-3
  no shutdown
interface vfc20
  bind interface Ethernet1/20
  switchport description HS-XEN-4
  no shutdown
interface vfc31
  bind interface Ethernet1/31
  no shutdown
interface vfc32
  bind interface Ethernet1/32
  no shutdown
vsan database
  vsan 332 interface vfc17
  vsan 332 interface vfc18
  vsan 332 interface vfc19
  vsan 332 interface vfc20
  vsan 332 interface vfc31
  vsan 332 interface vfc32
  switchport mode trunk
  switchport access vlan 330
  switchport trunk allowed vlan 34,300,310,320,330
  spanning-tree port type edge trunk
  description VNX (B8) B1-P0
  switchport trunk allowed vlan 330
  description VNX (A8) A1-P0
When we change the VSAN and VLAN, the flogi information dissapears for the EMC VNX5500. The Flogi information is still present for the four Dell servers
changed VSAN and VLAN
vlan 102
  fcoe vsan 1002
vlan 300,310,320,330
vpc domain 100
vsan database
  vsan 1002
  vsan 1002 wwn 21:00:00:c0:dd:1a:69:c7 fcid 0xae0000 dynamic
  vsan 1002 wwn 21:00:00:c0:dd:1a:67:db fcid 0xae0001 dynamic
  vsan 1002 wwn 21:00:00:c0:dd:1a:6a:4f fcid 0xae0002 dynamic
  vsan 1002 wwn 21:00:00:c0:dd:1a:68:07 fcid 0xae0003 dynamic
interface vfc17
  switchport trunk allowed vsan 1002
  no shutdown
interface vfc18
  no shutdown
interface vfc19
  no shutdown
interface vfc20
  no shutdown
interface vfc31
  no shutdown
interface vfc32
  no shutdown
vsan database
  vsan 1002 interface vfc17
  vsan 1002 interface vfc18
  vsan 1002 interface vfc19
  vsan 1002 interface vfc20
  vsan 1002 interface vfc31
  vsan 1002 interface vfc32
  switchport access vlan 102
  switchport trunk allowed vlan 102
Is there a set procedure for changing VLAN and VSAN's ?
Thanks!
dynamoxxx
Level 5
Level 5
shut , no shut of those ports would not help ?
@dynamoxxx
Thanks for the response. Shut/ No Shut does not work. I am in contact with EMC. We will also upgrade to 5.2 NX-OS
jlgjr
We found the problem. The VNX uses VLAN tagging. The original install team set the wrong vlan. We changed the VNX vlan and the FLOGI's are now visible.
JG
