NPIV won't want to log in
jrodrigval
Hi friends,
We have some wwn (NPIV) that a few days ago where logged to the switch (just log, we don't worked with them). Today we are tring to check if they are log ged in to the switch to create the alias, zones, etc but checking if they are logged they aren't and we don't know what to do to force the log in or something like that.
The unix team just turn on the hba's to log in the switch, after few days turned off and today they turn on again and we can't see the wwn's logged.
Checking in DCNM I can see those wwn were logged, unix team turn off the system and the wwn dosen't log again to create alias, zones, etc:
Fabric_ESINTXFD1CORE1 128 HOST_c0507608c8e70034 c0:50:76:08:c8:e7:00:34 0xa206ac ESINTXFD1CORE1 fc3/35 last seen 2016/09/01-23:33:03
Fabric_ESINTXFD1CORE1 128 HOST_c0507608c8e70035 c0:50:76:08:c8:e7:00:35 0xa206b0 ESINTXFD1CORE1 fc3/35 last seen 2016/09/01-23:33:03
Fabric_ESINTXFD1CORE1 128 HOST_c0507608c8e7003a c0:50:76:08:c8:e7:00:3a 0xa206af ESINTXFD1CORE1 fc3/35 last seen 2016/09/01-23:33:03
Fabric_ESINTXFD1CORE1 128 HOST_c0507608c8e7003b c0:50:76:08:c8:e7:00:3b 0xa206b1 ESINTXFD1CORE1 fc3/35 last seen 2016/09/01-23:33:03
Fabric_ESINTXFD1CORE1 128 HOST_c0507608c8e70042 c0:50:76:08:c8:e7:00:42 0xa206ad ESINTXFD1CORE1 fc3/35 last seen 2016/09/01-23:33:03
Fabric_ESINTXFD1CORE1 128 HOST_c0507608c8e70043 c0:50:76:08:c8:e7:00:43 0xa206b2 ESINTXFD1CORE1 fc3/35 last seen 2016/09/01-23:33:03
(I'm trying upload a image but doesn't work)
Please, what we could do to log in those wwn's???
Thank you.
13 Replies 13
Walter Dey
What is the version of SAN-OS ?
Which MDS model ?
OS trying to log in ?
Any error seen on the MDS: show logging log ?
device alias or fc-alias ?
enhanced zoning ?
Please post the following CLI output
show flogi database vsan x
Hi Walter,
Thanks for your help, In red I answer you:
BIOS: version 3.1.0
kickstart: version 6.2(1)
system: version 6.2(1)
Which MDS model ?
Switch type is : MDS 9710 (10 Slot) Chassis
Model number is DS-C9710
H/W version is 1.2
AiX (7100-04-01) ===> Pseries ===> Vio ===> Lpar.
I attached the log file with the log since August 23, but I checked and didn't see any relevant.
We use fc-alias but in this case the wwn does not log in so I could't even begin to create the alias, zones, etc.
enhanced zoning ?
I would say no.... but I copy the "show zone status vsan 128" output:
ESINTXFD1CORE1# show zone status vsan 128
VSAN: 128 default-zone: deny distribute: full Interop: default
mode: basic merge-control: allow
session: none
hard-zoning: enabled broadcast: unsupported
smart-zoning: disabled
rscn-format: fabric-address
Default zone:
qos: none broadcast: unsupported ronly: unsupported
Full Zoning Database :
DB size: 105884 bytes
Zonesets:1 Zones:402 Aliases: 409
Active Zoning Database :
DB size: 32352 bytes
Name: datos_vsan128 Zonesets:1 Zones:401
Status: Activation completed at 15:14:47 UTC Sep 7 2016
I attached the file.
Again, thanks for your help.
Cheers.
Do I miss something ? I don't see any attached file.
In the past I had a case very similar to yours !
AIX uses class 2 and class 3 for flogi ! In my case I had a N5k, which only supported class 3.
That fix to the AIX to force class 3 at all times should stop these messages in the N5K logs.
16:11:15 %KERN-3-SYSTEM_MSG: [38620129.811115] fc2_nsh_tx_frame: FC2 s_id/d_id/vsan error: sid=0xfffffe,did=0x0,vsan=100,rctl:0xc3,type:0x0,oxid 0x1,rxid:0xffff – kernel
I would be interested it also resolved these messages.
VIOS1:
 Oct  9 10:48:22 fscsi4     T FCP_ERR12           Nameserver GID_PN or GPN_ID failed by adapter driver
 Oct  9 10:48:22 fscsi4     T FCP_ERR4            ioctl() send seq failure for port 0xFFFFFC; ENODEV
 Oct  9 10:48:20 fscsi4     T FCP_ERR12           Nameserver GID_PN or GPN_ID failed by adapter driver
 Oct  9 10:48:20 fscsi4     T FCP_ERR4            ioctl() send seq failure for port 0xFFFFFC; ENODEV
 Oct  9 10:48:17 fscsi8     T FCP_ERR12           Nameserver GID_PN or GPN_ID rejected with reason code 00000013
 Oct  9 10:48:17 fscsi8     T FCP_ERR4            ioctl() send seq failure for port 0xFFFFFC; ENODEV
 Oct  9 10:48:17 fscsi4     T FCP_ERR12           Nameserver GID_PN or GPN_ID rejected with reason code 00000013
 Oct  9 10:48:17 fscsi4     T FCP_ERR4            ioctl() send seq failure for port 0xFFFFFC; ENODEV
 Oct  9 10:48:15 fscsi8     T FCP_ERR12           Nameserver GID_PN or GPN_ID rejected with reason code 00000013
What the reason code is reporting is that the server has issued a query for an object in the GID-PN or GPN-ID command, for something that is not currently registered in the N5K FCNS data base (fiber channel name server).
Hi Walter,
I trying attach the files but lately I don't know why but this forum is going so wrong.
(Paste the outputs here).
My apologies sir.
show flogi database vsan 128:
ESINTXFD1CORE1# show flogi database vsan 128
INTERFACE VSAN FCID PORT NAME NODE NAME
fc1/1 128 0xa20140 50:05:07:68:0c:11:2b:ed 50:05:07:68:0c:00:2b:ed
fc1/2 128 0xa20000 50:05:07:68:0c:11:2b:f6 50:05:07:68:0c:00:2b:f6
fc1/3 128 0xa20080 50:05:07:68:0c:11:2b:e2 50:05:07:68:0c:00:2b:e2
fc1/4 128 0xa20020 50:05:07:68:0c:11:2b:f7 50:05:07:68:0c:00:2b:f7
fc1/8 128 0xa20060 20:00:00:c0:dd:29:18:6b 10:00:00:c0:dd:29:18:6b
fc1/8 128 0xa20061 21:00:00:24:ff:4b:e3:72 20:00:00:24:ff:4b:e3:72
fc1/8 128 0xa20062 21:00:00:24:ff:4b:fb:02 20:00:00:24:ff:4b:fb:02
fc1/8 128 0xa20063 21:00:00:24:ff:4b:ff:a0 20:00:00:24:ff:4b:ff:a0
fc1/8 128 0xa20064 21:00:00:24:ff:4b:ff:e0 20:00:00:24:ff:4b:ff:e0
fc1/8 128 0xa20065 21:00:00:24:ff:4b:f9:b4 20:00:00:24:ff:4b:f9:b4
fc1/9 128 0xa20100 10:00:00:90:fa:a7:74:f4 20:00:01:20:fa:a7:74:f4
fc1/9 128 0xa20101 c0:50:76:08:a0:45:00:00 c0:50:76:08:a0:45:00:00
fc1/9 128 0xa20103 c0:50:76:08:a0:45:00:1c c0:50:76:08:a0:45:00:1c
fc1/9 128 0xa20105 c0:50:76:08:a0:45:00:0c c0:50:76:08:a0:45:00:0c
fc1/9 128 0xa20107 c0:50:76:08:a0:45:00:16 c0:50:76:08:a0:45:00:16
fc1/9 128 0xa20109 c0:50:76:08:a0:45:00:24 c0:50:76:08:a0:45:00:24
fc1/9 128 0xa2010b c0:50:76:08:a0:45:00:2c c0:50:76:08:a0:45:00:2c
fc1/9 128 0xa2010d c0:50:76:08:a0:45:00:36 c0:50:76:08:a0:45:00:36
fc1/9 128 0xa2010f c0:50:76:08:a0:45:00:3c c0:50:76:08:a0:45:00:3c
fc1/9 128 0xa20111 c0:50:76:08:a0:45:00:44 c0:50:76:08:a0:45:00:44
fc1/9 128 0xa20114 c0:50:76:08:a0:45:00:6c c0:50:76:08:a0:45:00:6c
fc1/9 128 0xa20116 c0:50:76:08:a0:45:00:56 c0:50:76:08:a0:45:00:56
fc1/9 128 0xa20118 c0:50:76:08:a0:45:00:7a c0:50:76:08:a0:45:00:7a
fc1/9 128 0xa2011a c0:50:76:08:a0:45:00:80 c0:50:76:08:a0:45:00:80
fc1/9 128 0xa2011e c0:50:76:08:a0:45:00:90 c0:50:76:08:a0:45:00:90
fc1/9 128 0xa203a0 c0:50:76:08:a0:45:00:9a c0:50:76:08:a0:45:00:9a
fc1/9 128 0xa203a5 c0:50:76:08:a0:45:00:b0 c0:50:76:08:a0:45:00:b0
fc1/9 128 0xa203a7 c0:50:76:08:a0:45:00:ba c0:50:76:08:a0:45:00:ba
fc1/9 128 0xa203a9 c0:50:76:08:a0:45:00:c0 c0:50:76:08:a0:45:00:c0
fc1/9 128 0xa203ab c0:50:76:08:a0:45:00:c8 c0:50:76:08:a0:45:00:c8
fc1/9 128 0xa203ad c0:50:76:08:a0:45:00:d0 c0:50:76:08:a0:45:00:d0
fc1/9 128 0xa203b1 c0:50:76:08:a0:45:00:da c0:50:76:08:a0:45:00:da
fc1/9 128 0xa203b3 c0:50:76:08:a0:45:00:e8 c0:50:76:08:a0:45:00:e8
fc1/9 128 0xa203b5 c0:50:76:08:a0:45:00:f0 c0:50:76:08:a0:45:00:f0
fc1/10 128 0xa20160 10:00:00:90:fa:a7:74:22 20:00:01:20:fa:a7:74:22
fc1/10 128 0xa20161 c0:50:76:08:a0:3f:00:00 c0:50:76:08:a0:3f:00:00
fc1/10 128 0xa20163 c0:50:76:08:a0:3f:00:18 c0:50:76:08:a0:3f:00:18
fc1/10 128 0xa20165 c0:50:76:08:a0:3f:00:08 c0:50:76:08:a0:3f:00:08
fc1/10 128 0xa20167 c0:50:76:08:a0:3f:00:12 c0:50:76:08:a0:3f:00:12
fc1/10 128 0xa20169 c0:50:76:08:a0:3f:00:20 c0:50:76:08:a0:3f:00:20
fc1/10 128 0xa2016b c0:50:76:08:a0:3f:00:28 c0:50:76:08:a0:3f:00:28
fc1/10 128 0xa2016d c0:50:76:08:a0:3f:00:32 c0:50:76:08:a0:3f:00:32
fc1/10 128 0xa2016e c0:50:76:08:a0:3f:00:38 c0:50:76:08:a0:3f:00:38
fc1/10 128 0xa2016f c0:50:76:08:a0:3f:00:40 c0:50:76:08:a0:3f:00:40
fc1/10 128 0xa20174 c0:50:76:08:a0:3f:00:68 c0:50:76:08:a0:3f:00:68
fc1/10 128 0xa20176 c0:50:76:08:a0:3f:00:72 c0:50:76:08:a0:3f:00:72
fc1/10 128 0xa20178 c0:50:76:08:a0:3f:00:52 c0:50:76:08:a0:3f:00:52
fc1/10 128 0xa2017a c0:50:76:08:a0:3f:00:78 c0:50:76:08:a0:3f:00:78
fc1/10 128 0xa2017c c0:50:76:08:a0:3f:00:80 c0:50:76:08:a0:3f:00:80
fc1/10 128 0xa203c2 c0:50:76:08:a0:45:00:67 c0:50:76:08:a0:45:00:67
fc1/10 128 0xa20400 c0:50:76:08:a0:3f:00:92 c0:50:76:08:a0:3f:00:92
fc1/10 128 0xa20402 c0:50:76:08:a0:3f:00:98 c0:50:76:08:a0:3f:00:98
fc1/10 128 0xa20406 c0:50:76:08:a0:3f:00:b2 c0:50:76:08:a0:3f:00:b2
fc1/10 128 0xa20408 c0:50:76:08:a0:3f:00:ba c0:50:76:08:a0:3f:00:ba
fc1/10 128 0xa2040a c0:50:76:08:a0:3f:00:c2 c0:50:76:08:a0:3f:00:c2
fc1/10 128 0xa2040c c0:50:76:08:a0:3f:00:d4 c0:50:76:08:a0:3f:00:d4
fc1/10 128 0xa2040e c0:50:76:08:a0:3f:00:ca c0:50:76:08:a0:3f:00:ca
fc1/10 128 0xa20410 c0:50:76:08:a0:3f:00:da c0:50:76:08:a0:3f:00:da
fc1/10 128 0xa20412 c0:50:76:08:a0:3f:00:e2 c0:50:76:08:a0:3f:00:e2
fc1/10 128 0xa20416 c0:50:76:08:a0:3f:00:f4 c0:50:76:08:a0:3f:00:f4
fc1/10 128 0xa20418 c0:50:76:08:a0:3f:00:fa c0:50:76:08:a0:3f:00:fa
fc1/11 128 0xa201a0 10:00:00:90:fa:72:44:44 20:00:00:90:fa:72:44:44
fc1/12 128 0xa20260 10:00:00:90:fa:72:44:45 20:00:00:90:fa:72:44:45
fc1/13 128 0xa20480 10:00:00:90:fa:72:44:64 20:00:00:90:fa:72:44:64
fc1/14 128 0xa204c0 10:00:00:90:fa:b2:37:3c 20:00:01:20:fa:b2:37:3c
fc1/14 128 0xa204d5 c0:50:76:08:c8:e5:00:00 c0:50:76:08:c8:e5:00:00
fc1/14 128 0xa204d6 c0:50:76:08:c8:e5:00:18 c0:50:76:08:c8:e5:00:18
fc1/14 128 0xa204d7 c0:50:76:08:c8:e5:00:20 c0:50:76:08:c8:e5:00:20
fc1/14 128 0xa204d8 c0:50:76:08:c8:e5:00:32 c0:50:76:08:c8:e5:00:32
fc1/14 128 0xa204d9 c0:50:76:08:c8:e5:00:38 c0:50:76:08:c8:e5:00:38
fc1/14 128 0xa204da c0:50:76:08:c8:e5:00:40 c0:50:76:08:c8:e5:00:40
fc1/14 128 0xa204df c0:50:76:08:c8:e5:00:08 c0:50:76:08:c8:e5:00:08
fc1/14 128 0xa20661 c0:50:76:08:c8:e5:00:12 c0:50:76:08:c8:e5:00:12
fc1/14 128 0xa20664 c0:50:76:08:c8:e5:00:21 c0:50:76:08:c8:e5:00:21
fc1/14 128 0xa20665 c0:50:76:08:c8:e5:00:50 c0:50:76:08:c8:e5:00:50
fc1/14 128 0xa20667 c0:50:76:08:c8:e5:00:58 c0:50:76:08:c8:e5:00:58
fc1/14 128 0xa20669 c0:50:76:08:c8:e5:00:60 c0:50:76:08:c8:e5:00:60
fc1/14 128 0xa2066b c0:50:76:08:c8:e5:00:68 c0:50:76:08:c8:e5:00:68
fc1/17 128 0xa20360 20:00:00:c0:dd:29:15:71 10:00:00:c0:dd:29:15:71
fc1/17 128 0xa20361 21:00:00:24:ff:4f:31:3c 20:00:00:24:ff:4f:31:3c
fc1/17 128 0xa20362 21:00:00:24:ff:4b:e5:be 20:00:00:24:ff:4b:e5:be
fc1/17 128 0xa20363 21:00:00:24:ff:4b:e5:f2 20:00:00:24:ff:4b:e5:f2
fc1/17 128 0xa20364 21:00:00:24:ff:4a:8f:32 20:00:00:24:ff:4a:8f:32
fc1/17 128 0xa20365 21:00:00:24:ff:4b:fb:7e 20:00:00:24:ff:4b:fb:7e
fc1/34 128 0xa206c0 10:00:00:90:fa:b2:84:32 20:00:01:20:fa:b2:84:32
fc1/35 128 0xa20681 10:00:00:90:fa:b4:3a:8c 20:00:01:20:fa:b4:3a:8c
fc1/35 128 0xa20682 c0:50:76:08:c8:e7:00:04 c0:50:76:08:c8:e7:00:04
fc1/35 128 0xa20684 c0:50:76:08:c8:e7:00:0c c0:50:76:08:c8:e7:00:0c
fc1/35 128 0xa20686 c0:50:76:08:c8:e7:00:1c c0:50:76:08:c8:e7:00:1c
fc1/35 128 0xa20688 c0:50:76:08:c8:e7:00:24 c0:50:76:08:c8:e7:00:24
fc1/35 128 0xa2068a c0:50:76:08:c8:e7:00:16 c0:50:76:08:c8:e7:00:16
fc1/35 128 0xa2068e c0:50:76:08:c8:e7:00:2c c0:50:76:08:c8:e7:00:2c
fc1/35 128 0xa2068f c0:50:76:08:c8:e7:00:36 c0:50:76:08:c8:e7:00:36
fc1/35 128 0xa20690 c0:50:76:08:c8:e7:00:44 c0:50:76:08:c8:e7:00:44
fc1/35 128 0xa20691 c0:50:76:08:c8:e7:00:2d c0:50:76:08:c8:e7:00:2d
fc1/35 128 0xa20692 c0:50:76:08:c8:e7:00:3c c0:50:76:08:c8:e7:00:3c
fc1/38 128 0xa205c0 10:00:00:90:fa:80:b8:4c 20:00:01:20:fa:80:b8:4c
fc1/38 128 0xa205c1 c0:50:76:08:36:35:00:0a c0:50:76:08:36:35:00:0a
fc1/38 128 0xa205c2 c0:50:76:08:36:35:00:10 c0:50:76:08:36:35:00:10
fc2/8 128 0xa200a0 20:0f:00:c0:dd:29:18:6b 10:00:00:c0:dd:29:18:6b
fc2/8 128 0xa200a1 21:00:00:24:ff:4b:f9:a2 20:00:00:24:ff:4b:f9:a2
fc2/8 128 0xa200a2 21:00:00:24:ff:4b:ff:84 20:00:00:24:ff:4b:ff:84
fc2/8 128 0xa200a3 21:00:00:24:ff:4b:fa:fe 20:00:00:24:ff:4b:fa:fe
fc2/8 128 0xa200a4 21:00:00:24:ff:4b:fb:08 20:00:00:24:ff:4b:fb:08
fc2/9 128 0xa20280 10:00:00:90:fa:85:4d:93 20:00:01:20:fa:85:4d:93
fc2/9 128 0xa20281 c0:50:76:08:a0:45:00:50 c0:50:76:08:a0:45:00:50
fc2/9 128 0xa20283 c0:50:76:08:a0:45:00:a4 c0:50:76:08:a0:45:00:a4
fc2/9 128 0xa20285 c0:50:76:08:a0:45:00:ac c0:50:76:08:a0:45:00:ac
fc2/9 128 0xa203af c0:50:76:08:a0:45:00:e0 c0:50:76:08:a0:45:00:e0
fc2/10 128 0xa202a0 10:00:00:90:fa:a7:69:97 20:00:01:20:fa:a7:69:97
fc2/10 128 0xa202a1 c0:50:76:08:a0:3f:00:4c c0:50:76:08:a0:3f:00:4c
fc2/10 128 0xa202a3 c0:50:76:08:a0:3f:00:a4 c0:50:76:08:a0:3f:00:a4
fc2/10 128 0xa202a5 c0:50:76:08:a0:3f:00:ac c0:50:76:08:a0:3f:00:ac
fc2/10 128 0xa20414 c0:50:76:08:a0:3f:00:ea c0:50:76:08:a0:3f:00:ea
fc2/11 128 0xa201c0 10:00:00:90:fa:72:61:5e 20:00:00:90:fa:72:61:5e
fc2/12 128 0xa202c0 10:00:00:90:fa:72:61:5f 20:00:00:90:fa:72:61:5f
fc2/17 128 0xa20380 20:0f:00:c0:dd:29:15:71 10:00:00:c0:dd:29:15:71
fc2/17 128 0xa20381 21:00:00:24:ff:4b:e4:1c 20:00:00:24:ff:4b:e4:1c
fc2/17 128 0xa20382 21:00:00:24:ff:4b:67:ec 20:00:00:24:ff:4b:67:ec
fc2/17 128 0xa20383 21:00:00:24:ff:4f:26:00 20:00:00:24:ff:4f:26:00
fc2/17 128 0xa20384 21:00:00:24:ff:4b:bf:b4 20:00:00:24:ff:4b:bf:b4
fc2/34 128 0xa20700 10:00:00:90:fa:b4:3a:00 20:00:01:20:fa:b4:3a:00
fc2/38 128 0xa20620 10:00:00:90:fa:80:c7:c6 20:00:01:20:fa:80:c7:c6
fc2/38 128 0xa20621 c0:50:76:08:36:35:00:0c c0:50:76:08:36:35:00:0c
fc2/38 128 0xa20622 c0:50:76:08:36:35:00:12 c0:50:76:08:36:35:00:12
fc3/8 128 0xa200c0 20:00:00:c0:dd:29:15:69 10:00:00:c0:dd:29:15:69
fc3/8 128 0xa200c1 21:00:00:24:ff:4b:e4:92 20:00:00:24:ff:4b:e4:92
fc3/8 128 0xa200c2 21:00:00:24:ff:4b:68:32 20:00:00:24:ff:4b:68:32
fc3/8 128 0xa200c3 21:00:00:24:ff:4b:e4:32 20:00:00:24:ff:4b:e4:32
fc3/8 128 0xa200c8 21:00:00:24:ff:4a:80:70 20:00:00:24:ff:4a:80:70
fc3/9 128 0xa20120 10:00:00:90:fa:85:4a:22 20:00:01:20:fa:85:4a:22
fc3/9 128 0xa20121 c0:50:76:08:a0:45:00:04 c0:50:76:08:a0:45:00:04
fc3/9 128 0xa20123 c0:50:76:08:a0:45:00:22 c0:50:76:08:a0:45:00:22
fc3/9 128 0xa20125 c0:50:76:08:a0:45:00:12 c0:50:76:08:a0:45:00:12
fc3/9 128 0xa20127 c0:50:76:08:a0:45:00:14 c0:50:76:08:a0:45:00:14
fc3/9 128 0xa20129 c0:50:76:08:a0:45:00:26 c0:50:76:08:a0:45:00:26
fc3/9 128 0xa2012b c0:50:76:08:a0:45:00:2e c0:50:76:08:a0:45:00:2e
fc3/9 128 0xa2012d c0:50:76:08:a0:45:00:38 c0:50:76:08:a0:45:00:38
fc3/9 128 0xa2012f c0:50:76:08:a0:45:00:3e c0:50:76:08:a0:45:00:3e
fc3/9 128 0xa20131 c0:50:76:08:a0:45:00:46 c0:50:76:08:a0:45:00:46
fc3/9 128 0xa20134 c0:50:76:08:a0:45:00:6e c0:50:76:08:a0:45:00:6e
fc3/9 128 0xa20136 c0:50:76:08:a0:45:00:54 c0:50:76:08:a0:45:00:54
fc3/9 128 0xa20138 c0:50:76:08:a0:45:00:7c c0:50:76:08:a0:45:00:7c
fc3/9 128 0xa2013a c0:50:76:08:a0:45:00:82 c0:50:76:08:a0:45:00:82
fc3/9 128 0xa2013e c0:50:76:08:a0:45:00:92 c0:50:76:08:a0:45:00:92
fc3/9 128 0xa203c0 c0:50:76:08:a0:45:00:9c c0:50:76:08:a0:45:00:9c
fc3/9 128 0xa203c5 c0:50:76:08:a0:45:00:b2 c0:50:76:08:a0:45:00:b2
fc3/9 128 0xa203c7 c0:50:76:08:a0:45:00:bc c0:50:76:08:a0:45:00:bc
fc3/9 128 0xa203c9 c0:50:76:08:a0:45:00:c2 c0:50:76:08:a0:45:00:c2
fc3/9 128 0xa203cb c0:50:76:08:a0:45:00:ca c0:50:76:08:a0:45:00:ca
fc3/9 128 0xa203cd c0:50:76:08:a0:45:00:d2 c0:50:76:08:a0:45:00:d2
fc3/9 128 0xa203cf c0:50:76:08:a0:45:00:e2 c0:50:76:08:a0:45:00:e2
fc3/9 128 0xa203d1 c0:50:76:08:a0:45:00:d8 c0:50:76:08:a0:45:00:d8
fc3/9 128 0xa203d3 c0:50:76:08:a0:45:00:ea c0:50:76:08:a0:45:00:ea
fc3/10 128 0xa20180 10:00:00:90:fa:a7:69:5e 20:00:01:20:fa:a7:69:5e
fc3/10 128 0xa20181 c0:50:76:08:a0:3f:00:02 c0:50:76:08:a0:3f:00:02
fc3/10 128 0xa20183 c0:50:76:08:a0:3f:00:1e c0:50:76:08:a0:3f:00:1e
fc3/10 128 0xa20185 c0:50:76:08:a0:3f:00:0a c0:50:76:08:a0:3f:00:0a
fc3/10 128 0xa20187 c0:50:76:08:a0:3f:00:10 c0:50:76:08:a0:3f:00:10
fc3/10 128 0xa20189 c0:50:76:08:a0:3f:00:22 c0:50:76:08:a0:3f:00:22
fc3/10 128 0xa2018b c0:50:76:08:a0:3f:00:2a c0:50:76:08:a0:3f:00:2a
fc3/10 128 0xa2018d c0:50:76:08:a0:3f:00:34 c0:50:76:08:a0:3f:00:34
fc3/10 128 0xa2018e c0:50:76:08:a0:3f:00:3a c0:50:76:08:a0:3f:00:3a
fc3/10 128 0xa2018f c0:50:76:08:a0:3f:00:42 c0:50:76:08:a0:3f:00:42
fc3/10 128 0xa20194 c0:50:76:08:a0:3f:00:6a c0:50:76:08:a0:3f:00:6a
fc3/10 128 0xa20196 c0:50:76:08:a0:3f:00:74 c0:50:76:08:a0:3f:00:74
fc3/10 128 0xa20198 c0:50:76:08:a0:3f:00:50 c0:50:76:08:a0:3f:00:50
fc3/10 128 0xa2019a c0:50:76:08:a0:3f:00:7a c0:50:76:08:a0:3f:00:7a
fc3/10 128 0xa2019c c0:50:76:08:a0:3f:00:82 c0:50:76:08:a0:3f:00:82
fc3/10 128 0xa203a2 c0:50:76:08:a0:45:00:65 c0:50:76:08:a0:45:00:65
fc3/10 128 0xa20420 c0:50:76:08:a0:3f:00:94 c0:50:76:08:a0:3f:00:94
fc3/10 128 0xa20422 c0:50:76:08:a0:3f:00:9a c0:50:76:08:a0:3f:00:9a
fc3/10 128 0xa20426 c0:50:76:08:a0:3f:00:b4 c0:50:76:08:a0:3f:00:b4
fc3/10 128 0xa20428 c0:50:76:08:a0:3f:00:bc c0:50:76:08:a0:3f:00:bc
fc3/10 128 0xa2042a c0:50:76:08:a0:3f:00:c4 c0:50:76:08:a0:3f:00:c4
fc3/10 128 0xa2042c c0:50:76:08:a0:3f:00:d2 c0:50:76:08:a0:3f:00:d2
fc3/10 128 0xa2042e c0:50:76:08:a0:3f:00:cc c0:50:76:08:a0:3f:00:cc
fc3/10 128 0xa20430 c0:50:76:08:a0:3f:00:dc c0:50:76:08:a0:3f:00:dc
fc3/10 128 0xa20432 c0:50:76:08:a0:3f:00:e4 c0:50:76:08:a0:3f:00:e4
fc3/10 128 0xa20436 c0:50:76:08:a0:3f:00:f6 c0:50:76:08:a0:3f:00:f6
fc3/10 128 0xa2043a c0:50:76:08:a0:3f:00:fc c0:50:76:08:a0:3f:00:fc
fc3/11 128 0xa20200 10:00:00:90:fa:72:43:c0 20:00:00:90:fa:72:43:c0
fc3/12 128 0xa20300 10:00:00:90:fa:72:43:c1 20:00:00:90:fa:72:43:c1
fc3/14 128 0xa20520 10:00:00:90:fa:b2:82:ea 20:00:01:20:fa:b2:82:ea
fc3/14 128 0xa20522 c0:50:76:08:c8:e5:00:30 c0:50:76:08:c8:e5:00:30
fc3/14 128 0xa20524 c0:50:76:08:c8:e5:00:3e c0:50:76:08:c8:e5:00:3e
fc3/14 128 0xa20526 c0:50:76:08:c8:e5:00:46 c0:50:76:08:c8:e5:00:46
fc3/14 128 0xa20528 c0:50:76:08:c8:e5:00:10 c0:50:76:08:c8:e5:00:10
fc3/14 128 0xa2052a c0:50:76:08:c8:e5:00:1e c0:50:76:08:c8:e5:00:1e
fc3/14 128 0xa2052c c0:50:76:08:c8:e5:00:0e c0:50:76:08:c8:e5:00:0e
fc3/14 128 0xa2052e c0:50:76:08:c8:e5:00:26 c0:50:76:08:c8:e5:00:26
fc3/14 128 0xa2052f c0:50:76:08:c8:e5:00:27 c0:50:76:08:c8:e5:00:27
fc3/14 128 0xa20530 c0:50:76:08:c8:e5:00:06 c0:50:76:08:c8:e5:00:06
fc3/14 128 0xa20537 c0:50:76:08:c8:e5:00:52 c0:50:76:08:c8:e5:00:52
fc3/14 128 0xa20539 c0:50:76:08:c8:e5:00:5a c0:50:76:08:c8:e5:00:5a
fc3/14 128 0xa2053b c0:50:76:08:c8:e5:00:66 c0:50:76:08:c8:e5:00:66
fc3/14 128 0xa2053c c0:50:76:08:c8:e5:00:6e c0:50:76:08:c8:e5:00:6e
fc3/17 128 0xa20440 20:00:00:c0:dd:29:15:53 10:00:00:c0:dd:29:15:53
fc3/17 128 0xa20441 21:00:00:24:ff:4b:f9:34 20:00:00:24:ff:4b:f9:34
fc3/17 128 0xa20443 21:00:00:24:ff:4b:e7:02 20:00:00:24:ff:4b:e7:02
fc3/17 128 0xa20445 21:00:00:24:ff:4b:e5:26 20:00:00:24:ff:4b:e5:26
fc3/17 128 0xa20447 21:00:00:24:ff:4b:c0:40 20:00:00:24:ff:4b:c0:40
fc3/17 128 0xa20449 21:00:00:24:ff:4b:e4:76 20:00:00:24:ff:4b:e4:76
fc3/34 128 0xa20720 10:00:00:90:fa:b4:3d:80 20:00:01:20:fa:b4:3d:80
fc3/35 128 0xa206a0 10:00:00:90:fa:b2:88:66 20:00:01:20:fa:b2:88:66
fc3/35 128 0xa206a1 c0:50:76:08:c8:e7:00:02 c0:50:76:08:c8:e7:00:02
fc3/35 128 0xa206a3 c0:50:76:08:c8:e7:00:0a c0:50:76:08:c8:e7:00:0a
fc3/35 128 0xa206a5 c0:50:76:08:c8:e7:00:14 c0:50:76:08:c8:e7:00:14
fc3/35 128 0xa206a7 c0:50:76:08:c8:e7:00:1a c0:50:76:08:c8:e7:00:1a
fc3/35 128 0xa206a9 c0:50:76:08:c8:e7:00:22 c0:50:76:08:c8:e7:00:22
fc3/38 128 0xa20640 10:00:00:90:fa:8a:fb:fa 20:00:01:20:fa:8a:fb:fa
fc3/38 128 0xa20641 c0:50:76:08:36:36:00:08 c0:50:76:08:36:36:00:08
fc3/38 128 0xa20642 c0:50:76:08:36:36:00:12 c0:50:76:08:36:36:00:12
fc3/38 128 0xa20643 c0:50:76:08:36:36:00:1a c0:50:76:08:36:36:00:1a
fc4/8 128 0xa20040 20:0f:00:c0:dd:29:15:69 10:00:00:c0:dd:29:15:69
fc4/8 128 0xa20041 21:00:00:24:ff:4b:72:08 20:00:00:24:ff:4b:72:08
fc4/8 128 0xa200c4 21:00:00:24:ff:4b:61:06 20:00:00:24:ff:4b:61:06
fc4/8 128 0xa200c5 21:00:00:24:ff:4f:1b:06 20:00:00:24:ff:4f:1b:06
fc4/8 128 0xa200c6 21:00:00:24:ff:4b:e4:f8 20:00:00:24:ff:4b:e4:f8
fc4/8 128 0xa200c7 21:00:00:24:ff:4b:e5:ea 20:00:00:24:ff:4b:e5:ea
fc4/9 128 0xa20320 10:00:00:90:fa:a7:72:69 20:00:01:20:fa:a7:72:69
fc4/9 128 0xa20321 c0:50:76:08:a0:45:00:52 c0:50:76:08:a0:45:00:52
fc4/9 128 0xa20323 c0:50:76:08:a0:45:00:a6 c0:50:76:08:a0:45:00:a6
fc4/9 128 0xa20325 c0:50:76:08:a0:45:00:ae c0:50:76:08:a0:45:00:ae
fc4/9 128 0xa20327 c0:50:76:08:a0:45:00:f6 c0:50:76:08:a0:45:00:f6
fc4/10 128 0xa20240 10:00:00:90:fa:a7:69:9b 20:00:01:20:fa:a7:69:9b
fc4/10 128 0xa20241 c0:50:76:08:a0:3f:00:4e c0:50:76:08:a0:3f:00:4e
fc4/10 128 0xa20243 c0:50:76:08:a0:3f:00:a6 c0:50:76:08:a0:3f:00:a6
fc4/10 128 0xa20245 c0:50:76:08:a0:3f:00:ae c0:50:76:08:a0:3f:00:ae
fc4/10 128 0xa20434 c0:50:76:08:a0:3f:00:ec c0:50:76:08:a0:3f:00:ec
fc4/11 128 0xa20220 10:00:00:90:fa:72:47:9c 20:00:00:90:fa:72:47:9c
fc4/12 128 0xa20340 10:00:00:90:fa:72:47:9d 20:00:00:90:fa:72:47:9d
fc4/17 128 0xa20442 21:00:00:24:ff:4b:f9:ee 20:00:00:24:ff:4b:f9:ee
fc4/17 128 0xa20444 21:00:00:24:ff:4b:fa:e4 20:00:00:24:ff:4b:fa:e4
fc4/17 128 0xa20446 21:00:00:24:ff:4b:67:6c 20:00:00:24:ff:4b:67:6c
fc4/17 128 0xa20448 21:00:00:24:ff:4b:ff:6a 20:00:00:24:ff:4b:ff:6a
fc4/17 128 0xa20460 20:0f:00:c0:dd:29:15:53 10:00:00:c0:dd:29:15:53
fc4/34 128 0xa20740 10:00:00:90:fa:b4:39:48 20:00:01:20:fa:b4:39:48
fc4/38 128 0xa20600 10:00:00:90:fa:8a:ac:ae 20:00:01:20:fa:8a:ac:ae
fc4/38 128 0xa20601 c0:50:76:08:36:36:00:0e c0:50:76:08:36:36:00:0e
fc4/38 128 0xa20602 c0:50:76:08:36:36:00:10 c0:50:76:08:36:36:00:10
fc4/38 128 0xa20603 c0:50:76:08:36:36:00:1c c0:50:76:08:36:36:00:1c
Total number of flogi = 242.
ESINTXFD1CORE1#
show logging log:
2016 Aug 23 06:22:48 ESINTXFD1CORE1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by e008819 on 172.30.154.125@pts/0
2016 Aug 23 06:29:20 ESINTXFD1CORE1 last message repeated 1 time
2016 Aug 23 07:00:17 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 128%$ Interface fc1/35 is up in mode F
2016 Aug 23 07:00:17 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 69%$ Interface fc2/35 is up in mode F
2016 Aug 23 12:21:05 ESINTXFD1CORE1 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user [A from 172.30.164.22 - sshd[4947]
2016 Aug 23 12:21:05 ESINTXFD1CORE1 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for illegal user [A from 172.30.164.22 - sshd[4944]
2016 Aug 23 12:21:11 ESINTXFD1CORE1 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user [A from 172.30.164.22 - sshd[4948]
2016 Aug 23 12:21:11 ESINTXFD1CORE1 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for illegal user [A from 172.30.164.22 - sshd[4944]
2016 Aug 23 14:43:57 ESINTXFD1CORE1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by E008908 on 172.30.164.22@pts/0
2016 Aug 23 22:59:11 ESINTXFD1CORE1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by E008908 on 172.30.164.21@pts/0
2016 Aug 24 07:43:24 ESINTXFD1CORE1 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user e008819 from 172.30.154.125 - sshd[19877]
2016 Aug 24 07:43:24 ESINTXFD1CORE1 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for e008819 from 172.30.154.125 - sshd[19876]
2016 Aug 24 07:43:31 ESINTXFD1CORE1 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user e008819 from 172.30.154.125 - sshd[19884]
2016 Aug 24 07:43:31 ESINTXFD1CORE1 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for e008819 from 172.30.154.125 - sshd[19876]
2016 Aug 24 08:01:50 ESINTXFD1CORE1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by e008819 on 172.30.154.125@pts/1
2016 Aug 24 11:21:11 ESINTXFD1CORE1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by E008840 on 172.30.164.22@pts/0
2016 Aug 24 11:22:17 ESINTXFD1CORE1 last message repeated 1 time
2016 Aug 29 07:49:06 ESINTXFD1CORE1 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user E008908 from 172.30.164.22 - sshd[19976]
2016 Aug 29 07:49:06 ESINTXFD1CORE1 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for E008908 from 172.30.164.22 - sshd[19972]
2016 Aug 29 07:49:49 ESINTXFD1CORE1 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user E008908 from 172.30.164.22 - sshd[19977]
2016 Aug 29 07:49:49 ESINTXFD1CORE1 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for E008908 from 172.30.164.22 - sshd[19972]
2016 Aug 29 07:49:56 ESINTXFD1CORE1 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user E008908 from 172.30.164.22 - sshd[19997]
2016 Aug 29 07:49:56 ESINTXFD1CORE1 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for E008908 from 172.30.164.22 - sshd[19972]
2016 Aug 29 07:50:23 ESINTXFD1CORE1 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user E008908 from 172.30.164.22 - sshd[20015]
2016 Aug 29 07:50:23 ESINTXFD1CORE1 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for E008908 from 172.30.164.22 - sshd[20013]
2016 Aug 29 07:50:30 ESINTXFD1CORE1 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user E008908 from 172.30.164.22 - sshd[20029]
2016 Aug 29 07:50:30 ESINTXFD1CORE1 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for E008908 from 172.30.164.22 - sshd[20013]
2016 Aug 30 11:23:17 ESINTXFD1CORE1 %USER-3-SYSTEM_MSG: can't get hostname of 127.5.1.5 - rpc.mountd
2016 Aug 30 12:08:38 ESINTXFD1CORE1 last message repeated 1 time
2016 Aug 30 15:02:57 ESINTXFD1CORE1 last message repeated 1 time
2016 Aug 30 17:15:47 ESINTXFD1CORE1 last message repeated 1 time
2016 Aug 30 17:16:18 ESINTXFD1CORE1 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user E008840 from 172.30.164.21 - sshd[3514]
2016 Aug 30 17:16:18 ESINTXFD1CORE1 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for E008840 from 172.30.164.21 - sshd[3508]
2016 Aug 30 17:39:12 ESINTXFD1CORE1 %USER-3-SYSTEM_MSG: can't get hostname of 127.5.1.5 - rpc.mountd
2016 Aug 30 17:56:47 ESINTXFD1CORE1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 128%$ Interface fc1/35 is down (Link failure loss of signal)
2016 Aug 30 17:56:48 ESINTXFD1CORE1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 69%$ Interface fc2/35 is down (Link failure loss of signal)
2016 Aug 30 17:58:25 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 69%$ Interface fc2/35 is up in mode F
2016 Aug 30 17:58:25 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 128%$ Interface fc1/35 is up in mode F
2016 Aug 30 18:06:17 ESINTXFD1CORE1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 128%$ Interface fc3/35 is down (Link failure loss of signal)
2016 Aug 30 18:06:17 ESINTXFD1CORE1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 69%$ Interface fc4/35 is down (Link failure loss of signal)
2016 Aug 30 18:07:26 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 128%$ Interface fc3/35 is up in mode F
2016 Aug 30 18:07:35 ESINTXFD1CORE1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 128%$ Interface fc3/35 is down (Link failure loss of signal)
2016 Aug 30 18:07:55 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 128%$ Interface fc3/35 is up in mode F
2016 Aug 30 18:07:55 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 69%$ Interface fc4/35 is up in mode F
2016 Aug 31 11:07:49 ESINTXFD1CORE1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by E008908 on 172.30.164.21@pts/0
2016 Aug 31 11:23:44 ESINTXFD1CORE1 last message repeated 1 time
2016 Aug 31 11:24:03 ESINTXFD1CORE1 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user E008908 from 172.30.164.21 - sshd[15734]
2016 Aug 31 11:24:03 ESINTXFD1CORE1 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for E008908 from 172.30.164.21 - sshd[15732]
2016 Aug 31 11:37:40 ESINTXFD1CORE1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by E008908 on 172.30.164.21@pts/0
2016 Aug 31 14:55:22 ESINTXFD1CORE1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by E008840 on 172.30.164.131@pts/1
2016 Aug 31 15:17:50 ESINTXFD1CORE1 last message repeated 1 time
2016 Aug 31 15:23:27 ESINTXFD1CORE1 last message repeated 1 time
2016 Aug 31 15:40:47 ESINTXFD1CORE1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by E008840 on 172.30.164.131@pts/0
2016 Aug 31 15:57:52 ESINTXFD1CORE1 last message repeated 1 time
2016 Aug 31 16:09:46 ESINTXFD1CORE1 %USER-3-SYSTEM_MSG: can't get hostname of 127.5.1.5 - rpc.mountd
2016 Aug 31 17:55:42 ESINTXFD1CORE1 last message repeated 1 time
2016 Aug 31 19:45:51 ESINTXFD1CORE1 last message repeated 1 time
2016 Aug 31 20:06:07 ESINTXFD1CORE1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 128%$ Interface fc2/10 is down (Link failure loss of signal)
2016 Aug 31 20:06:07 ESINTXFD1CORE1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 128%$ Interface fc1/10 is down (Link failure loss of signal)
2016 Aug 31 20:06:52 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 128%$ Interface fc1/10 is up in mode F
2016 Aug 31 20:07:06 ESINTXFD1CORE1 %PORT-4-IF_SFP_WARNING: Interface fc1/10, Low Rx Power Warning
2016 Aug 31 20:07:06 ESINTXFD1CORE1 %PORT-3-IF_SFP_ALARM: Interface fc1/10, Low Rx Power Alarm
2016 Aug 31 20:07:06 ESINTXFD1CORE1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 128%$ Interface fc1/10 is down (Link failure loss of signal)
2016 Aug 31 20:07:20 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 128%$ Interface fc1/10 is up in mode F
2016 Aug 31 20:07:20 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 128%$ Interface fc2/10 is up in mode F
2016 Aug 31 20:08:49 ESINTXFD1CORE1 %USER-3-SYSTEM_MSG: can't get hostname of 127.5.1.5 - rpc.mountd
2016 Aug 31 20:12:35 ESINTXFD1CORE1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 128%$ Interface fc3/10 is down (Link failure loss of signal)
2016 Aug 31 20:12:35 ESINTXFD1CORE1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 128%$ Interface fc4/10 is down (Link failure loss of signal)
2016 Aug 31 20:13:24 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 128%$ Interface fc3/10 is up in mode F
2016 Aug 31 20:13:34 ESINTXFD1CORE1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 128%$ Interface fc3/10 is down (Link failure loss of signal)
2016 Aug 31 20:13:53 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 128%$ Interface fc3/10 is up in mode F
2016 Aug 31 20:13:53 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 128%$ Interface fc4/10 is up in mode F
2016 Aug 31 20:14:48 ESINTXFD1CORE1 %USER-3-SYSTEM_MSG: can't get hostname of 127.5.1.5 - rpc.mountd
2016 Aug 31 20:16:55 ESINTXFD1CORE1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 128%$ Interface fc2/10 is down (Link failure loss of signal)
2016 Aug 31 20:16:55 ESINTXFD1CORE1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 128%$ Interface fc1/10 is down (Link failure loss of signal)
2016 Aug 31 20:17:44 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 128%$ Interface fc1/10 is up in mode F
2016 Aug 31 20:17:54 ESINTXFD1CORE1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 128%$ Interface fc1/10 is down (Link failure loss of signal)
2016 Aug 31 20:18:13 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 128%$ Interface fc1/10 is up in mode F
2016 Aug 31 20:18:13 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 128%$ Interface fc2/10 is up in mode F
2016 Aug 31 20:19:06 ESINTXFD1CORE1 %USER-3-SYSTEM_MSG: can't get hostname of 127.5.1.5 - rpc.mountd
2016 Aug 31 20:27:07 ESINTXFD1CORE1 %PORT-4-IF_SFP_WARNING: Interface fc1/10, Low Rx Power Warning cleared
2016 Aug 31 20:27:07 ESINTXFD1CORE1 %PORT-3-IF_SFP_ALARM: Interface fc1/10, Low Rx Power Alarm cleared
2016 Aug 31 20:59:21 ESINTXFD1CORE1 %USER-3-SYSTEM_MSG: can't get hostname of 127.5.1.5 - rpc.mountd
2016 Aug 31 21:11:10 ESINTXFD1CORE1 last message repeated 1 time
2016 Sep 1 14:22:34 ESINTXFD1CORE1 last message repeated 1 time
2016 Sep 1 15:21:17 ESINTXFD1CORE1 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user E008840 from 172.30.164.22 - sshd[21541]
2016 Sep 1 15:21:17 ESINTXFD1CORE1 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for E008840 from 172.30.164.22 - sshd[21506]
2016 Sep 1 15:28:29 ESINTXFD1CORE1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by E008840 on 172.30.164.22@pts/0
2016 Sep 1 15:30:35 ESINTXFD1CORE1 last message repeated 1 time
2016 Sep 1 15:48:58 ESINTXFD1CORE1 last message repeated 1 time
2016 Sep 1 20:17:33 ESINTXFD1CORE1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 128%$ Interface fc1/9 is down (Link failure loss of signal)
2016 Sep 1 20:17:33 ESINTXFD1CORE1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 128%$ Interface fc2/9 is down (Link failure loss of signal)
2016 Sep 1 20:18:18 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 128%$ Interface fc1/9 is up in mode F
2016 Sep 1 20:21:45 ESINTXFD1CORE1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 128%$ Interface fc1/9 is down (Link failure loss of signal)
2016 Sep 1 20:22:05 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 128%$ Interface fc1/9 is up in mode F
2016 Sep 1 20:22:05 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 128%$ Interface fc2/9 is up in mode F
2016 Sep 1 20:22:57 ESINTXFD1CORE1 %USER-3-SYSTEM_MSG: can't get hostname of 127.5.1.5 - rpc.mountd
2016 Sep 1 20:28:18 ESINTXFD1CORE1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 128%$ Interface fc4/9 is down (Link failure loss of signal)
2016 Sep 1 20:28:18 ESINTXFD1CORE1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 128%$ Interface fc3/9 is down (Link failure loss of signal)
2016 Sep 1 20:29:04 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 128%$ Interface fc3/9 is up in mode F
2016 Sep 1 20:29:12 ESINTXFD1CORE1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 128%$ Interface fc3/9 is down (Link failure loss of signal)
2016 Sep 1 20:29:32 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 128%$ Interface fc4/9 is up in mode F
2016 Sep 1 20:29:32 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 128%$ Interface fc3/9 is up in mode F
2016 Sep 1 20:30:25 ESINTXFD1CORE1 %USER-3-SYSTEM_MSG: can't get hostname of 127.5.1.5 - rpc.mountd
2016 Sep 1 20:37:26 ESINTXFD1CORE1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 128%$ Interface fc2/9 is down (Link failure loss of signal)
2016 Sep 1 20:37:26 ESINTXFD1CORE1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 128%$ Interface fc1/9 is down (Link failure loss of signal)
2016 Sep 1 20:38:11 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 128%$ Interface fc1/9 is up in mode F
2016 Sep 1 20:38:20 ESINTXFD1CORE1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 128%$ Interface fc1/9 is down (Link failure loss of signal)
2016 Sep 1 20:38:40 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 128%$ Interface fc2/9 is up in mode F
2016 Sep 1 20:38:40 ESINTXFD1CORE1 %PORT-5-IF_UP: %$VSAN 128%$ Interface fc1/9 is up in mode F
2016 Sep 1 20:39:44 ESINTXFD1CORE1 %USER-3-SYSTEM_MSG: can't get hostname of 127.5.1.5 - rpc.mountd
2016 Sep 1 21:33:35 ESINTXFD1CORE1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by admin on vsh.4524
2016 Sep 2 10:35:42 ESINTXFD1CORE1 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user E008840 from 172.30.164.21 - sshd[3624]
2016 Sep 2 10:35:42 ESINTXFD1CORE1 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for E008840 from 172.30.164.21 - sshd[3619]
2016 Sep 2 10:35:45 ESINTXFD1CORE1 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user E008840 from 172.30.164.21 - sshd[3627]
2016 Sep 2 10:35:45 ESINTXFD1CORE1 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for E008840 from 172.30.164.21 - sshd[3619]
2016 Sep 2 10:35:53 ESINTXFD1CORE1 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user E008840 from 172.30.164.21 - sshd[3628]
2016 Sep 2 10:35:53 ESINTXFD1CORE1 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for E008840 from 172.30.164.21 - sshd[3619]
2016 Sep 2 11:19:54 ESINTXFD1CORE1 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user E008840 from 172.30.164.21 - sshd[5677]
2016 Sep 2 11:19:54 ESINTXFD1CORE1 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for E008840 from 172.30.164.21 - sshd[5676]
2016 Sep 2 14:21:05 ESINTXFD1CORE1 %USER-3-SYSTEM_MSG: can't get hostname of 127.5.1.5 - rpc.mountd
2016 Sep 6 10:10:50 ESINTXFD1CORE1 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user E008908 from 172.30.154.28 - sshd[8351]
2016 Sep 6 10:10:50 ESINTXFD1CORE1 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for E008908 from 172.30.154.28 - sshd[8350]
2016 Sep 6 10:13:59 ESINTXFD1CORE1 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user E008908 from 172.30.154.28 - sshd[8469]
2016 Sep 6 10:13:59 ESINTXFD1CORE1 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for E008908 from 172.30.154.28 - sshd[8468]
2016 Sep 6 11:03:46 ESINTXFD1CORE1 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user E003453 from 172.30.164.21 - sshd[10524]
2016 Sep 6 11:03:46 ESINTXFD1CORE1 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for E003453 from 172.30.164.21 - sshd[10520]
2016 Sep 6 11:03:52 ESINTXFD1CORE1 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user E003453 from 172.30.164.21 - sshd[10527]
2016 Sep 6 11:03:52 ESINTXFD1CORE1 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for E003453 from 172.30.164.21 - sshd[10520]
2016 Sep 7 11:34:15 ESINTXFD1CORE1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by E003453 on 172.30.164.131@pts/1
2016 Sep 7 14:27:20 ESINTXFD1CORE1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by E003453 on 172.30.164.21@pts/0
2016 Sep 7 15:04:54 ESINTXFD1CORE1 last message repeated 1 time
P.S.- There is something I should try or do meanwhile?.
Thank you very much for your help.
Cheers.
Do you see any strange error messages on the AIX system ?
If you don't see a flogi entry, and the server has sent a flogi request, then MDS has done a reject, and you should see this in the log, and on the server.
Therefore verify, that the server sends a flogi request ! and check above !
Hi Walter,
Talking with the AiX team they send to me this:
lpar_name=dxd761,lpar_id=12,profile_name=normal,slot_num=42,wwpn=c0507608c8e7004a,wwpn_status=2,logged_in=unknown,wwpn_status_reason=Adapter is busy
lpar_name=dxd761,lpar_id=12,profile_name=normal,slot_num=42,wwpn=c0507608c8e7004b,wwpn_status=2,logged_in=unknown,wwpn_status_reason=Adapter is busy
says something to you?, in my humble opinion looks like a problem of they and not a switch problem, what do you think?
Thanks.
In my customer case, they had a IBM case open for months without any progress !
I would open a IBM case ! I agree with you, most likely this has nothing to do with MDS !
Did you check, when AIX is booted, no flogi entry is seen, what the MDS error log shows ?
Is this a Emulex or Qlogic adaptor ?
Please ask the server guys, that they only send class 3 FC frames, and not a mix of class 2 and 3 !
This is configurable on the HBA.
I ask the server guys and sadly they don't know if they send class 2, 3 or 1000.... They look to me as if I was talking in Chinese...
We know (for sure) a couple of things, in the MDS there is not log about this or even related and I've check the "show logging", "show fcns" details, statistics, etc, etc, etc and second thing is that once all wwn's (8) were logged and now two of them does not log in and those two are in Core 1, with Core 2 there is not problem at all.
Because that reason I still a little suspicious with the switches, but yes, I agree with you that this seems a server/AiX/VIO problem.
The adaptor is a Emulex.
Thank you.
What do you mean by core 1 resp core 2 ? are this the 2 fabrics (meaning separate physical MDS) and also different VSAN's ?
Thanks for any clarification !
Hi Walter,
First at all my apologies for no answer until now but I've been sick.
Sorry, yes by Core 1&2 I mean fabric 1&2 but same VSAN's.
Finally, The Unix team "fix" the problem so the issue came from their side.
Today I am just "landing" so I am trying to find out what happened...
Thanks for all.
Hi jrodrigval,
i hope you are well. I have almost the same issue except off that i have esxi and none of the vms where logged into san.
Best regards,
Daniel
were this issue resolved? What was the fix? I am going to integrate 9710 with IBM P700 series soon.
were you able to identify what was the fix done on AIX?
