NTP configuration
miguellangelo
Community Member
Is setting the Network Time Protocol disruptive to a Fabric while switch is already setup and running in a live environment?
Michael Brown
No, adding NTP to the configuration is not disruptive. The time stamps in the system log might shift if the clock changes as a result of the NTP addition, but that is not disruptive to the switch operation.
Michael Brown
Ok, thanks for yor help.
can you help me again?
I recently set the ntp server but the clock continue with the old time and date.
what's necessary to ntp update the system time?
thanks in advance.
