Performance Collector is in STARTING state
kiran.sn
Hi All,
Performance Collector is in STARTING state and the only event found in the FMS:
2009.01.22 23:36:57 WARN [fms.disc] persist fabric error: ERROR: duplicate key violates unique constraint "enclosure_pkey"
org.postgresql.util.PSQLException: ERROR: duplicate key violates unique constraint "enclosure_pkey"
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:1512)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1297)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:188)
at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:437)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:353)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeUpdate(AbstractJdbc2Statement.java:307)
at org.apache.commons.dbcp.DelegatingPreparedStatement.executeUpdate(DelegatingPreparedStatement.java:101)
at com.cisco.dcbu.sm.server.db.InventoryPersistentManager.persistFabricEnclosures(InventoryPersistentManager.java:1571)
at com.cisco.dcbu.sm.server.db.InventoryPersistentManager.persistFabric(InventoryPersistentManager.java:1841)
at com.cisco.dcbu.sm.server.discovery.FabricWorker.discover(FabricWorker.java:381)
at com.cisco.dcbu.sm.server.discovery.FabricWorker.run(FabricWorker.java:182)
at java.lang.Thread.run(Unknown Source)
The only thing I can suspect is the database server.
Any suggestion pls..?
Kiran
jejoseph
Looks like there is a corruption in Database, probably may need to clean up.
Can u open Cisco TAC case, so that
it can be corrected ?
sbilgi
Level 5
Level 5
follow the bug CSCdp01919 - DataSetServer remains in starting state using previous Repository.
Thank you for your reply. But I was not able see any information about the Bug as I dont have access to the limited resource.
Would it be possible to give me some information about that bug..?
Thank you,
Regards...
jejoseph
