Port Channel Exchange Based Load Balancing
a-watkins
Hi all.
With exchange-based load balancing, how is the link within the port-channel selected for each exchange? Is it round robin or is there something more intelligent?
We are using FCIP with two links with diverse routes. So the port-channel has 2 members, one with a rtt latency of 4ms and one with 14ms. Will half of the frames encur the 14ms latency or will more traffic use the lower-latency link?
Any help appreciated.
Allan.
mkoch
Level 4
Level 4
the port channel does not change the load balancing behaviour, it just makes your network more resilient to topology changes.
So the load balancing would be exchange-based (src/dest/oxid) or flow based (src/dest). This parameter is configurable per VSAN.
The latency is not a parameter anywhere.
Michael
