Power consumption calculator
vpantuhin
I can?t find Subj for the MDS switches. If such resource exists, please give me direct link to it.
smahbub
Level 6
Level 6
Cisco Power Calculator: URL - http://tools.cisco.com/cpc/launch.jsp
Calculate the power supply requirements for a specific Power over Ethernet (PoE) configuration for the Cisco Catalyst 6500, 4500, 3750, and 3560 series switches, or the Cisco 7600 Series Router. The results show output current, output power, and system heat dissipation.
What about MDS switches?
http://www.cisco.com/assets/prod/sn/ps6409/mds9000_power_calculator/dashboard.html
Is there a current calc?
I just went to this and I need to do a 9396S, but none of the 16 Gb or 97xx switches are on there.
