Problem Installing Fabric Manager 3.2.3 on W2K3
fmonettehp
Hello. I am trying to install Fabric Manager 3.2.3 on W2K3 and after starting the GUI, it is stopped with no error messages. It is working OK on Windows XP.
I have attached a shockwave to show you what I did
Any help ??
Gary Ross
Level 4
Level 4
When you did the command line, is the m9000-fm-3.2.3.jar file in the specified location?
Since I took it (cut/paste) from the Install gui, I am expecting that the GUI gave me the right installation path. Am I right ???
I would get the location to see if the JAR file is there.
Also, I ran into this problem with an IBM install where the path to the install files was either to long and had spaces in it. If you have the CD, I would install it from there since your current path is very long and has spaces in it.
The IBM software I was trying to install was TPC that relies heavily on Java.
let me try it from a shorter path and let you know the result
thanks
