We have some problems witch channels to the FICON SAN switches: channel 56 on Mainframe1 to switch 5B5 (FDBELF5C1_VSAN500_DISK) and channel 28 (on Mainframe1) to switch 5B7 (FDBELF5C1_VSAN510_TAPE). Forr Mainframe2 the channels are 35 to 5B5 and 37 to 5B7.
Hereby an example for switch 5B5 and channels 56 (BAD) and 43 (GOOD):
---> command: D M=DEV(5B5)
IEE174I 10.21.40 DISPLAY M 494
DEVICE 05B5 STATUS=ONLINE
CHP 56 43
ENTRY LINK ADDRESS 6543 655B
DEST LINK ADDRESS 75FE 75FE
PATH ONLINE
N Y
CHP PHYSICALLY ONLINE Y Y
PATH OPERATIONAL Y Y
MANAGED N N
CU NUMBER 05B5 05B5
MAXIMUM MANAGED CHPID(S) ALLOWED: 0
DESTINATION CU LOGICAL ADDRESS = 00
SCP CU ND = 0MDS9K.513.CSC.1F.00059B7ACEC4.00E0
SCP TOKEN NED = 0MDS9K.513.CSC.1F.00059B7ACEC4.0000
SCP DEVICE NED = 0MDS9K.513.CSC.1F.00059B7ACEC4.0000
When one tries to put the path online then the following error messages are seen:
---> command: VARY PATH(5B5,56),ONLINE
IEE386I PATH(05B5,56) NOT BROUGHT ONLINE
IEE763I NAME= IOSCCMSG CODE= 0000000800000032
IOS291I CONFIGURATION DATA COULD NOT BE READ ON PATH(05B5,56) RC=32
DEVICE SUPPORT CODE DETECTED INCORRECT CDR DATA
IEE763I NAME= IECVIOPM CODE= 0000000400000000
IOS554I CONFIGURATION DATA PROCESSING FAILED
IEE764I END OF IEE386I RELATED MESSAGES µ
We don't think that the problem is port related but switch related!
For the moment problems are present on only one of our 4 mainframe SAN directors. Firmware level of the directors was changed 3 weeks ago to NX-OS 4.2(7b).
