Question regarding Zone set activation difference
bonnu0606
Community Member
I got a quick question  on SAN Core switch which is running 4.X version. When I try to add some new zones and activate the zoneset, it is showing some old zones that were added a month ago to be added still to the active zoneset. But before I go and activate the zone set, if I log into one of those servers which was added earlier it looks perfectly fine. Is there any way to fix this ? Please find attached file
chris.walden
Community Member
It would appear that you are using basic (not enhanced) zoning, and you have differences in the local zoning database (on the switch where your zoning is being implemented) versus what is in effect elsewhere in the fabric.  How do you have zoneset distribution configured elsewhere?  Do you make it a practice to distribute your changes after they are activated?
