Redundancy state: No present
jrodrigval
Hi all,
After a planned power outage our mds 9513 started with one of the supervisor module (module 8) like this:
Mod       Ports     Module-Type                                 Model                            Status
1             24         1/2/4 Gbps FC Module           DS-X9124                            ok
2             24         1/2/4 Gbps FC Module           DS-X9124 ok
3             48         1/2/4 Gbps FC Module           DS-X9148 ok
4             48         1/2/4 Gbps FC Module           DS-X9148 ok
5             48         1/2/4 Gbps FC Module           DS-X9148 ok
6             48         1/2/4 Gbps FC Module           DS-X9148 ok
7             0           Supervisor/Fabric-2             DS-X9530-SF2-K9          active *
8             0           Supervisor/Fabric-2                                                      powered-up
9             48         1/2/4 Gbps FC Module           DS-X9148 ok
10           24         1/2/4 Gbps FC Module           DS-X9124 ok
11           24         1/2/4 Gbps FC Module           DS-X9124 ok
And constantly we have this events:
2017 Feb 8 14:29:42 CNA252040RSAN %SYSMGR-2-STANDBY_BOOT_FAILED: Standby supervisor failed to boot up.
2017 Feb 8 14:29:42 CNA252040RSAN %CALLHOME-2-EVENT: SUP_FAILURE
2017 Feb 8 14:39:43 CNA252040RSAN %SYSMGR-2-STANDBY_BOOT_FAILED: Standby supervisor failed to boot up.
2017 Feb 8 14:39:43 CNA252040RSAN %CALLHOME-2-EVENT: SUP_FAILURE
2017 Feb 8 14:49:44 CNA252040RSAN %SYSMGR-2-STANDBY_BOOT_FAILED: Standby supervisor failed to boot up.
2017 Feb 8 14:49:44 CNA252040RSAN %CALLHOME-2-EVENT: SUP_FAILURE
2017 Feb 8 14:59:44 CNA252040RSAN %SYSMGR-2-STANDBY_BOOT_FAILED: Standby supervisor failed to boot up.
2017 Feb 8 14:59:44 CNA252040RSAN %CALLHOME-2-EVENT: SUP_FAILURE
2017 Feb 8 15:09:45 CNA252040RSAN %SYSMGR-2-STANDBY_BOOT_FAILED: Standby supervisor failed to boot up.
2017 Feb 8 15:09:45 CNA252040RSAN %CALLHOME-2-EVENT: SUP_FAILURE
2017 Feb 8 15:19:45 CNA252040RSAN %SYSMGR-2-STANDBY_BOOT_FAILED: Standby supervisor failed to boot up.
2017 Feb 8 15:19:45 CNA252040RSAN %CALLHOME-2-EVENT: SUP_FAILURE
2017 Feb 8 15:29:46 CNA252040RSAN %SYSMGR-2-STANDBY_BOOT_FAILED: Standby supervisor failed to boot up.
2017 Feb 8 15:29:46 CNA252040RSAN %CALLHOME-2-EVENT: SUP_FAILURE
2017 Feb 8 15:39:47 CNA252040RSAN %SYSMGR-2-STANDBY_BOOT_FAILED: Standby supervisor failed to boot up.
2017 Feb 8 15:39:47 CNA252040RSAN %CALLHOME-2-EVENT: SUP_FAILURE
2017 Feb 8 15:49:47 CNA252040RSAN %SYSMGR-2-STANDBY_BOOT_FAILED: Standby supervisor failed to boot up.
2017 Feb 8 15:49:47 CNA252040RSAN %CALLHOME-2-EVENT: SUP_FAILURE
2017 Feb 8 15:59:48 CNA252040RSAN %SYSMGR-2-STANDBY_BOOT_FAILED: Standby supervisor failed to boot up.
2017 Feb 8 15:59:48 CNA252040RSAN %CALLHOME-2-EVENT: SUP_FAILURE
We thought that maybe it was a problem in the supervisor module and our hardware service replace it but we continues with the same problem.
Also if I launch this:
CNA252040RSAN# show system redundancy status
Redundancy mode
administrative: HA
operational: None
This supervisor (sup-1)
Redundancy state: Active
Supervisor state: Active
Internal state: Active with no standby
Other supervisor (sup-2)
Redundancy state: Not present
or this:
CNA252040RSAN# attach module 8
module 8 is not present
Please, somebody knows what happens?
What could we do?
Walter Dey
Could it be
Standby sup stuck in powered-up: fcns failed to store its snapshot
CSCuc85584
Description
Symptom:
Standby supervisor remains in powered-up status and fails to reach standby status. show logging logfilecontains the following messages:
%SYSMGR-2-GSYNC_SNAPSHOT_SRVFAILED: Service "fcns" on active supervisor failed to store its snapshot (error-id 0x80480018).
Conditions:
This issue only occurs if the standby supervisor has rebooted more than 200 times since active supervisor became active.
Workaround:
Contact Cisco TAC to workaround this issue.
Customer Visible
Notifications
Save Bug
Open Support Case
Was the description about this Bug Helpful?
(0)
Details
Last Modified:
Jan 18,2017
Status:
Fixed
Severity:
3 Moderate
Product:
(1)
Cisco MDS 9000 Series Multilayer Switches
Support Cases:
53
Known Affected Releases:
(1)
5.2(2d)
Known Fixed Releases:
(16)
5.2(8)
5.2(8)S24
5.2(9.39)S0
6.2(1)S37
6.2(1.50)S0
7.0(0)ZD(0.53)
7.0(0)ZD(0.55)
7.0(0.7)
7.0(3)IFC2(1)
7.0(3)IFC2(1.2)
7.0(3)IFC3(1)
7.0(3)IFC3(1.2)
7.0(3)IFD1(0.1)
7.0(3)IFD1(1)
7.0(3)ITI2(1)
7.0(3)ITI2(1.60)
Community Discussion on CSCuc85584 - Cisco Support Community
Thanks for your help.
Finally after a couple of module supervisor replacement all is working well.
We think the first replace spare part was DOA.
Again, Thanks for your help.
