SAN Device Manager port on Green X
denz_cruel
Hi Everyone,
Can anyone explain me what is the meaning of green X on the SAN Device manager port 5? Please see details below image and cli command. I am not sure if the port is faulty or just wrong information by device manager.
SANCORE-1B# sh int fc1/5
fc1/5 is up
    Port description is SNCISQL01A HBA Slot 2
    Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN)
    Port WWN is 20:05:00:0d:ec:ba:9d:80
    Admin port mode is F, trunk mode is off
    snmp link state traps are enabled
    Port mode is F, FCID is 0x870200
    Port vsan is 2
    Speed is 4 Gbps
    Rate mode is dedicated
    Transmit B2B Credit is 3
    Receive B2B Credit is 16
    Receive data field Size is 2112
    Beacon is turned off
    5 minutes input rate 12683848 bits/sec, 1585481 bytes/sec, 1261 frames/sec
    5 minutes output rate 61312488 bits/sec, 7664061 bytes/sec, 4307 frames/sec
      30170465636 frames input, 50914835047204 bytes
        0 discards, 0 errors
        0 CRC,  0 unknown class
        0 too long, 0 too short
      85246711848 frames output, 159546341238872 bytes
        5 discards, 0 errors
      224 input OLS, 4 LRR, 42 NOS, 0 loop inits
      47 output OLS, 71 LRR, 186 NOS, 0 loop inits
      16 receive B2B credit remaining
      3 transmit B2B credit remaining
     3 low priority transmit B2B credit remaining
    Interface last changed at Mon Jul 22 15:14:06 2013
denz_cruel
  SAN Device manager green X on port 5 disapeared, we did not do anything (shut/unshut the port). Must be a bug.
