Several Errors per day: PORT-5-IF_DOWN_LINK_FAILURE
nunobarbosa12
Greetings,
All my MDS are reporting issues such as Link Failure on several ports since May. Everyday, a new report is shows up and in a diferent fcport.
The troubleshooting document says that could be a physical issue, but I already checked.
Who can help me with this situation?
Kind Regards,
Nuno Barbosa
-----------------------------------------------------------------------------------LOG--------------------------------------------------------------------------------------------------------
2012 Jul 17 21:34:47 MDS-PDC-A-01 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 1%$ Interface fc1/26 is down (Link failure loss of sync)  "ZECA"
2012 Jul 17 21:36:55 MDS-PDC-A-01 %PORT-5-IF_UP: %$VSAN 1%$ Interface fc1/26 is up in mode F  "ZECA"
2012 Jul 17 21:57:03 MDS-PDC-A-01 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 1%$ Interface fc2/29 is down (Link failure loss of signal)  "ADIDAS"
2012 Jul 17 21:58:19 MDS-PDC-A-01 %PORT-5-IF_UP: %$VSAN 1%$ Interface fc2/29 is up in mode F  "ADIDAS"
2012 Jul 17 22:25:33 MDS-PDC-A-01 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 1%$ Interface fc5/17 is down (Link failure loss of signal)  "NIKE"
2012 Jul 17 22:26:44 MDS-PDC-A-01 %PORT-5-IF_UP: %$VSAN 1%$ Interface fc5/17 is up in mode F  "NIKE"
2012 Jul 17 22:26:49 MDS-PDC-A-01 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 1%$ Interface fc5/14 is down (Link failure loss of signal)  "PUMA"
2012 Jul 17 22:28:09 MDS-PDC-A-01 %PORT-5-IF_UP: %$VSAN 1%$ Interface fc5/14 is up in mode F  "PUMA"
2012 Jul 17 22:33:54 MDS-PDC-A-01 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 1%$ Interface fc10/6 is down (Link failure loss of sync)  "LACATONI"
2012 Jul 17 22:34:52 MDS-PDC-A-01 %PORT-5-IF_UP: %$VSAN 1%$ Interface fc10/6 is up in mode F  "LACATONI"
2012 Jul 19 10:17:30 MDS-PDC-A-01 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 1%$ Interface fc5/10 is down (Link failure loss of signal)  "AIRNESS"
2012 Jul 19 10:26:03 MDS-PDC-A-01 %PORT-5-IF_UP: %$VSAN 1%$ Interface fc5/10 is up in mode F  "AIRNESS"
2012 Jul 20 15:44:37 MDS-PDC-A-01 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 1%$ Interface fc5/10 is down (Link failure loss of signal)  "AIRNESS"
2012 Jul 20 16:21:06 MDS-PDC-A-01 %PORT-5-IF_UP: %$VSAN 1%$ Interface fc5/10 is up in mode F  "AIRNESS"
2012 Jul 23 06:06:26 MDS-PDC-A-01 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 1%$ Interface fc10/5 is down (Link failure loss of signal)  "HUMMEL"
2012 Jul 23 06:09:16 MDS-PDC-A-01 %PORT-5-IF_UP: %$VSAN 1%$ Interface fc10/5 is up in mode F  "HUMMEL"
Brian Morrissey
Hi Nuno,
What kind of devices are attached to these interfaces?  Could be those devices are being rebooted for maintenance etc and drop connectivity to the san..
Brian Morrissey
Hi Nuno,
Hello Brian,
Thank you for your prompt reply.
This is a production cisco MDS 9513 and it is attached with servers, storage and has 2 ISL ports for a MDS C-Class on a HP BladeCenter C7000 Enclosure.
I noticed that these 2 ISL ports (2 each Fabric), has the following configuration:
MDS-PDC-A-01# sh interface fc1/22
fc1/22 is up
    Port description is "APRICOT ISL"
    Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN)
    Port WWN is 20:16:54:7f:ee:0c:ff:00
    Peer port WWN is 20:0a:00:05:73:b0:1d:00
    Admin port mode is E, trunk mode is off
    snmp link state traps are enabled
    Port mode is E
    Port vsan is 1
    Speed is 4 Gbps
    Rate mode is dedicated
    Transmit B2B Credit is 16
    Receive B2B Credit is 250
    B2B State Change Number is 14
    Receive data field Size is 2112
    Beacon is turned off
    5 minutes input rate 34634640 bits/sec, 4329330 bytes/sec, 2795 frames/sec
    5 minutes output rate 21801240 bits/sec, 2725155 bytes/sec, 2136 frames/sec
      25993853586 frames input, 49791309768576 bytes
        0 discards, 0 errors
        0 CRC,  0 unknown class
        0 too long, 0 too short
      20875538315 frames output, 37636600208268 bytes
      0 input OLS, 0 LRR, 0 NOS, 0 loop inits
      0 output OLS, 0 LRR, 0 NOS, 0 loop inits
      250 receive B2B credit remaining
      16 transmit B2B credit remaining
      14 low priority transmit B2B credit remaining
    Interface last changed at Fri Feb 10 10:45:50 2012
MDS-PDC-A-01# sh interface fc1/25
fc1/25 is up
    Port WWN is 20:19:54:7f:ee:0c:ff:00
    Peer port WWN is 20:0e:00:05:73:b0:1d:00
    Port mode is E
    Port vsan is 1
    Speed is 4 Gbps
    5 minutes input rate 33142624 bits/sec, 4142828 bytes/sec, 2681 frames/sec
    5 minutes output rate 21496712 bits/sec, 2687089 bytes/sec, 2081 frames/sec
      25991642560 frames input, 49789094273784 bytes
      20877265630 frames output, 37637676357644 bytes
    Interface last changed at Fri Feb 10 10:47:04 2012
Nuno,
I'm having the same problem, did you solved your?
Thanks in advance,
Roberto
