The switch is not authenticating via radius
Chetan R
Hello Team
kickstart: version 4.2(7d)
system:    version 4.2(7d)
2011 Apr 14 18:03:43 jiph101f01 %RADIUS-3-RADIUS_ERROR_MESSAGE: All RADIUS servers failed to respond after retries.
2011 Apr 14 18:03:45 jiph101f01 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user E406803 from 169.111.36.203 - sshd[13276]
2011 Apr 14 18:03:45 jiph101f01 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for illegal user E406803 from 169.111.36.203 - sshd[13275]
2011 Apr 14 18:04:12 jiph101f01 %RADIUS-3-RADIUS_ERROR_MESSAGE: Failed looking up IP address for RADIUS server 204.27.45.5
2011 Apr 14 18:04:12 jiph101f01 %RADIUS-3-RADIUS_ERROR_MESSAGE: Failed looking up IP address for RADIUS server 204.27.45.69
2011 Apr 14 18:04:12 jiph101f01 %RADIUS-3-RADIUS_ERROR_MESSAGE: All RADIUS servers failed to respond after retries.
2011 Apr 14 18:04:14 jiph101f01 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user E406803 from 169.111.36.203 - sshd[13278]
2011 Apr 14 18:04:14 jiph101f01 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for illegal user E406803 from 169.111.36.203 - sshd[13277]
2011 Apr 14 18:04:42 jiph101f01 %RADIUS-3-RADIUS_ERROR_MESSAGE: Failed looking up IP address for RADIUS server 204.27.45.5
2011 Apr 14 18:04:42 jiph101f01 %RADIUS-3-RADIUS_ERROR_MESSAGE: Failed looking up IP address for RADIUS server 204.27.45.69
2011 Apr 14 18:04:42 jiph101f01 %RADIUS-3-RADIUS_ERROR_MESSAGE: All RADIUS servers failed to respond after retries.
2011 Apr 14 18:04:45 jiph101f01 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user E406803 from 169.111.36.203 - sshd[13327]
2011 Apr 14 18:04:45 jiph101f01 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for illegal user E406803 from 169.111.36.203 - sshd[13323]
2011 Apr 14 18:04:57 jiph101f01 %SYSMGR-2-SERVICE_CRASHED: Service "Radius Daemon" (PID 2949) hasn't caught signal 11 (core will be saved).
Service "Radius Daemon" ("radius", 4):
        UUID = 0xB7, PID = 13350, SAP = 113
        State: SRV_STATE_HANDSHAKED (entered at time Thu Apr 14 18:04:58 2011).
        Restart count: 2
        Time of last restart: Thu Apr 14 18:04:57 2011.
        Previous PID: 2949
        Reason of last termination: SYSMGR_DEATH_REASON_FAILURE_SIGNAL
        Tag = N/A
      Plugin ID: 0
`show cores`
Module-num       Instance-num      Process-name     PID      Core-create-time
7                1                radius            2949     Apr 14 18:05
Please Advise
Chetan.R
kenk
Hi Chetan,
I would recommend that you copy the core file off to a tftp server, and then open a new
TAC Service Request to have the core file analyzed (for a known bug or if this is a previously
unseen crash).
Ken
Hi Chetan,
I am also facing the same problem
kickstart: version 6.1(2)
system:    version 6.1(2)
By any chance, did we find the solution?
thnaks,
Yam
