Trace port channel members
johnnywilhelm
Is there a way to trace the members of a port channel from show tech-supports from the core and edge switches?
I have a large SAN and need to verify the config.
I want to identify the switch and interface for both ends of the port channel.
Eg, on the core switch I have:
`show port-channel usage`
Totally 12 port-channel numbers used
Used  :   1 - 4 , 11 - 12 , 21 - 22 , 31 - 32 , 41 - 42
Unused:   5 - 10 , 13 - 20 , 23 - 30 , 33 - 40 , 43 - 256
`show port-channel summary`
Interface                 Total Ports        Oper Ports        First Oper Port
port-channel 1                 12                12                 fc2/2
port-channel 2                 12                12                 fc2/10
port-channel 3                 12                12                 fc3/4
port-channel 4                 12                12                 fc4/7
port-channel 11                6                 5                  fc12/5
port-channel 12                6                 6                  fc13/4
port-channel 21                6                 6                  fc10/2
port-channel 22                6                 6                  fc11/2
port-channel 31                6                 6                  fc12/8
port-channel 32                6                 6                  fc13/7
port-channel 41                6                 6                  fc10/8
port-channel 42                6                 6                  fc11/7
and i expect that port-channel 1 is on this edge:
Totally 1 port-channel number used
Used  :   1
Unused:   2 - 256
port-channel 1                 12                12                 fc9/2
Does the port-channel name have to be unique on both ends?
I can trace F_ports via the FLOGIs, but I can't seem to find anything similar for TE_ports?
Vu Phan
This may help
switch# sho port-channel internal info interface port-channel 1
port-channel 1
channel    : 1
bundle     : 0
ifindex    : 0x4000000
admin mode : active
oper mode  : active
nports     : 2
active     : 2
bundle     : 0
wwn        : 24:01:00:0d:ec:2c:54:c0
peer wwn   : 24:01:00:0d:ec:81:e2:00          < ---  Peer switch
flag       : 0
lock count : 0
ac mbrs    : 0 0
xgfc_status: 0
Members:
fc1/12 fc1/13
Lock Info: resource [port-channel 1]
Vu Phan
This may help
port-channel 1
channel    : 1
bundle     : 0
ifindex    : 0x4000000
admin mode : active
oper mode  : active
nports     : 2
active     : 2
bundle     : 0
flag       : 0
lock count : 0
ac mbrs    : 0 0
xgfc_status: 0
Members:
fc1/12 fc1/13
Thanks Vu - that is it.
In the log, the command is:
`show tech-support port-channel`
One further question, what is the bundle in the output?
port-channel 1
channel : 1
bundle : 0
ifindex : 0x4000000
admin mode : active
oper mode : active
nports : 2
active : 2
bundle : 0
flag : 0
lock count : 0
ac mbrs : 0 0
xgfc_status: 0
