Write Erase - will I lose license info?
richclaxton
I have a requirement to move 2 x MDS9513 switches from one site to another and add them into an existing fabric.
The configuration will need to be erased once moved in order to re-configure IP addresses, switch name etc.
The plan is to perform a "write erase"
My question is : Will a "write erase" delete any license information held on the switch?
Rich
calopez2
Please be sure to have backup Licenses before doing a "write erase" on the MDS switch.
Pease see here from Obtaining and Installing Licenses:
http://www.cisco.com/en/US/customer/products/ps5989/products_configuration_guide_chapter09186a0080664c67.html
Tip We recommend backing up your license files immediately after installing them and just before issuing a write erase command.
I hope this helps.
Carlos
