Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
In order to zone a target and an initiator, they either need to be part of the same VSAN (that VSAN needs to be merged between physical switches) or use IVR.
Thanks @dynamoxxx. Does the configuration above suffice the requirements since same VSAN will be used across SAN switches. Does ISL link must be configured as well? From the setup above, from SAN-C perspective local server2 must be zoned with server1 in SAN-A.
Learn, share, save
