Using Cisco Zone Migrator
nflnetwork
Level 4
Level 4
in the documentation for this tool it says that port-based and domain-based zones are not support for migration
we are using brocade switches but I'm not sure of the zone types.
Cisco Zone Migrator does not support domain-based or port-based zone conversion. If any zone member types are unknown in the Brocade configuration, please change them manually before taking the “cfgshow” output. If the tool finds any domain-based or port-based zoning configuration in the “cfgshow” output, it will create a log file with error messages for domain-based and port-based zone members.
Does anyone know how to check this? What other types of zones would there be ?
thanks,
Bhavin Yadav
Hi nflnetwork,
please read thru BRCD FOS admin guide: https://docs.broadcom.com/doc/FOS-90x-Admin-AG Page 376 onwards...
Bhavin Yadav
it will show up as pwwn instead of wwn in the config.
is this what you mean?
FCSW01:FID128:admin> switchshow -portname
switchName:     FCSW01
switchType:     109.1
switchState:    Online
switchMode:     Native
switchRole:     Principal
switchDomain:   7
switchId:       fffc07
switchWwn:      10:00:50:eb:1a:8f:3f:c3
zoning:         ON (BottomSwitch)
switchBeacon:   OFF
FC Router:      OFF
HIF Mode:       OFF
Allow XISL Use: OFF
LS Attributes:  [FID: 128, Base Switch: No, Default Switch: Yes, Address Mode 0]
Index Port    PortWWN                   Name
   0   0   20:00:50:eb:1a:8f:3f:c3    port0
   1   1   20:01:50:eb:1a:8f:3f:c3    port1
   2   2   20:02:50:eb:1a:8f:3f:c3    port2
   3   3   20:03:50:eb:1a:8f:3f:c3    port3
   4   4   20:04:50:eb:1a:8f:3f:c3    port4
   5   5   20:05:50:eb:1a:8f:3f:c3    port5
   6   6   20:06:50:eb:1a:8f:3f:c3    port6
   7   7   20:07:50:eb:1a:8f:3f:c3    port7
   8   8   20:08:50:eb:1a:8f:3f:c3    port8
   9   9   20:09:50:eb:1a:8f:3f:c3    port9
  10  10   20:0a:50:eb:1a:8f:3f:c3    port10
  11  11   20:0b:50:eb:1a:8f:3f:c3    port11
  12  12   20:0c:50:eb:1a:8f:3f:c3    port12
  13  13   20:0d:50:eb:1a:8f:3f:c3    port13
  14  14   20:0e:50:eb:1a:8f:3f:c3    port14
  15  15   20:0f:50:eb:1a:8f:3f:c3    port15
  16  16   20:10:50:eb:1a:8f:3f:c3    port16
  17  17   20:11:50:eb:1a:8f:3f:c3    port17
  18  18   20:12:50:eb:1a:8f:3f:c3    port18
  19  19   20:13:50:eb:1a:8f:3f:c3    port19
  20  20   20:14:50:eb:1a:8f:3f:c3    port20
  21  21   20:15:50:eb:1a:8f:3f:c3    port21
  22  22   20:16:50:eb:1a:8f:3f:c3    port22
  23  23   20:17:50:eb:1a:8f:3f:c3    port23
  24  24   20:18:50:eb:1a:8f:3f:c3    port24
  25  25   20:19:50:eb:1a:8f:3f:c3    port25
  26  26   20:1a:50:eb:1a:8f:3f:c3    port26
  27  27   20:1b:50:eb:1a:8f:3f:c3    port27
  28  28   20:1c:50:eb:1a:8f:3f:c3    port28
  29  29   20:1d:50:eb:1a:8f:3f:c3    port29
  30  30   20:1e:50:eb:1a:8f:3f:c3    port30
  31  31   20:1f:50:eb:1a:8f:3f:c3    port31
  32  32   20:20:50:eb:1a:8f:3f:c3    port32
  33  33   20:21:50:eb:1a:8f:3f:c3    port33
  34  34   20:22:50:eb:1a:8f:3f:c3    port34
  35  35   20:23:50:eb:1a:8f:3f:c3    port35
  36  36   20:24:50:eb:1a:8f:3f:c3    port36
  37  37   20:25:50:eb:1a:8f:3f:c3    port37
  38  38   20:26:50:eb:1a:8f:3f:c3    port38
  39  39   20:27:50:eb:1a:8f:3f:c3    port39
  40  40   20:28:50:eb:1a:8f:3f:c3    port40
  41  41   20:29:50:eb:1a:8f:3f:c3    port41
  42  42   20:2a:50:eb:1a:8f:3f:c3    port42
  43  43   20:2b:50:eb:1a:8f:3f:c3    port43
  44  44   20:2c:50:eb:1a:8f:3f:c3    port44
  45  45   20:2d:50:eb:1a:8f:3f:c3    port45
  46  46   20:2e:50:eb:1a:8f:3f:c3    port46
  47  47   20:2f:50:eb:1a:8f:3f:c3    port47
can you try using the latest one from github: https://github.com/CiscoMDS/ZoneMigratorTool
