Zone two host between two different MDS in ISL
vbespiritu
Can this setup possible? Can i zone svr1 and svr2 that belongs in two different SAN switch?
dynamoxxx
Level 5
Level 5
In order to zone a target and an initiator, they either need to be part of the same VSAN (that VSAN needs to be merged between physical switches) or use IVR.
@dynamoxxx
Thanks @dynamoxxx. Does the configuration above suffice the requirements since same VSAN will be used across SAN switches. Does ISL link must be configured as well? From the setup above, from SAN-C perspective local server2 must be zoned with server1 in SAN-A.
