08-06-2013 07:20 AM - edited 03-20-2019 07:36 PM
Hi, I'm planning a large deployment that includes both 6880 and 2960X switches. Are there visio stencils available for these models? If not, does anyone know when they will become available?
08-27-2013 02:54 PM
Did you ever get an answer for this?
08-28-2013 01:35 PM
I did not. I'm currently using a .jpeg of the box.
12-06-2013 06:44 AM
Any updates on it?
12-26-2013 03:07 PM
Still nothing, I'm afraid. You'd think they'd be on this considering how much they're pushing these platforms and how many people are buying them.
01-03-2014 03:22 AM
The cisco inclued the Cat 6880 & 2960X stencils in there visio stencils library.
They can be downloaded from here:
10-31-2014 12:39 AM
Yes right ! the "Switches-Catalyst 2960" archive contain 2960-X stencils ...I am not concern about 6880 but I can see some stencil on "Switches-Catalyst 6880" archive.
Thanks a lot for this topic
02-23-2015 06:34 AM
I checked the Switch-Catalyst 2960 archive and I didn't find the 2960-X stencil inside. The archive date 23/May/2012. If someone finds it, please let me know.
Adil
anasser@itctransco.com
12-18-2019 04:53 PM
For anyone else, like me, who didn't understand any of the replies below, what I did was:
- Download the latest 2960 stencil available - NO 2960X stencils visible
- Download the 6800 series stencil and add to Visio
- 2960X stencils were then visible in the 2960 menu. - ??
It's crazy but it worked for me
12-18-2019 01:05 PM
12-18-2019 01:06 PM
NO THEY ARE NOT. It's all 2960S models. And nothing newer than 2015 or so. THERE ARE NO TEMPLATES AVAILABLE FOR 2960X MODELS.
12-18-2019 04:52 PM
@njsanders1 wrote:NO THEY ARE NOT. It's all 2960S models. And nothing newer than 2015 or so. THERE ARE NO TEMPLATES AVAILABLE FOR 2960X MODELS.
Hey brother. I understand your frustration because I was in exactly the same situation some time ago.
Check out my reply at the bottom of the thread.
05-25-2015 06:45 PM
You can check this page for a list of all stencils:
http://www.cisco.com/c/en/us/products/visio-stencil-listing.html
the 6800 stencil is available:
http://www.cisco.com/c/dam/assets/prod/visio/visio/switches_catalyst-6800.zip
the 2960 is also available:
http://www.cisco.com/c/dam/assets/prod/visio/visio/products_visio_icon0900aecd80395a84.zip
05-08-2019 06:57 PM
- Download the latest 2960 stencil available - no 2960X stencils visible
- Downlaod the 6800 series stencil and add to Visio
