6880 and 2960X Visio Stencils
joseph-foley
Hi, I'm planning a large deployment that includes both 6880 and 2960X switches.  Are there visio stencils available for these models?  If not, does anyone know when they will become available?
13 Replies 13
jasonbothe
Did you ever get an answer for this?
I did not.  I'm currently using a .jpeg of the box.
menonigeorge
Any updates on it?
Still nothing, I'm afraid.  You'd think they'd be on this considering how much they're pushing these platforms and how many people are buying them.
The cisco inclued the Cat 6880 & 2960X stencils in there visio stencils library.
They can be downloaded from here:
http://www.cisco.com/en/US/products/hw/prod_cat_visios.html
Yes right ! the "Switches-Catalyst 2960" archive contain 2960-X stencils ...I am not concern about 6880 but I can see some stencil on "Switches-Catalyst 6880" archive.
Thanks a lot for this topic
I checked the Switch-Catalyst 2960 archive and I didn't find the 2960-X stencil inside.  The archive date 23/May/2012.  If someone finds it, please let me know.
Adil
anasser@itctransco.com
For anyone else, like me, who didn't understand any of the replies below, what I did was:
- Download the latest 2960 stencil available - NO 2960X stencils visible
- Download the 6800 series stencil and add to Visio
- 2960X stencils were then visible in the 2960 menu. - ??
It's crazy but it worked for me
No, they do NOT. Only 2960S models are in that file.
NO THEY ARE NOT.  It's all 2960S models.  And nothing newer than 2015 or so.  THERE ARE NO TEMPLATES AVAILABLE FOR 2960X MODELS.
Hey brother. I understand your frustration because I was in exactly the same situation some time ago.
Check out my reply at the bottom of the thread.
Re: 6880 and 2960X Visio Stencils
Sandeep Ramakrishnan
You can check this page for a list of all stencils:
http://www.cisco.com/c/en/us/products/visio-stencil-listing.html
the 6800 stencil is available:
http://www.cisco.com/c/dam/assets/prod/visio/visio/switches_catalyst-6800.zip
the 2960 is also available:
http://www.cisco.com/c/dam/assets/prod/visio/visio/products_visio_icon0900aecd80395a84.zip
James Tuson
- Download the latest 2960 stencil available - no 2960X stencils visible
- Downlaod the 6800 series stencil and add to Visio
