AutoCAD Drawing Blocks
mgerbasio
I asked this in another section and was referred to this section.
I'm looking for an AutoCAD drawing (block) of the Cisco Catalyst 2955 Network Switch. Is one available? Thanks.
Regards-Michael
Beverly Fannion
Thank you for your inquiry regarding the Cisco Catalyst 2955.  Auto cad drawings are not available but Visio images can be found at:
http://www.cisco.com/en/US/products/prod_visio_icon_list.html
Attached is a sample Visio product image of the Catalyst 2955
Beverly Fannion
Thanks Bev. I'll take a look.
Do you by any chance have the CAD Drawing for the Cisco Catalyst 3850-12S-S Switch?
