Cisco 8200 router with NIM-4FXO; How to configure SRST
ksgoodman
I am new to SRST. Currently I have a 2901 router that is running SRST. This 2901 is being replaced by a 8200L-1N-4T that is running IOS 17.12.4a. Installed in the 8200 is a NIM-4FXO. Before getting into how to configure this new router, I have a few questions I need help with:
1. Can an 8200 with a NIM run SRST? When connected to this new router, I see there is a "esrst" command, so I am not sure if can run SRST or if I need to use ESRST. I am not sure I have the proper equipment or IOS to implement SRST. This is really the first thing I need help with.
2. Many of the commands from the 2901 router config conveyed to the 8200. In the original config there is a section "dspfarm profile 1 conference" where codec can be set. When I access the FXO card in the 8200, I see the "codec" command but the router kicks back "unrecognized command".  I don't know if dspfarm commands even apply to my setup.
3. Would it be possible to get a copy of a generic config in which  SRST (or ESRST if applicable)?
4. Lastly, are there any docs out there that walk you through the configuration process for SRST for an 8200?
Thanks in advance.
