Cisco Icon Library
dave.chadwick
Visitor
Im looking for an upto date Cisco Icon library, that contains not only the older PPT icons but also the newer HW such as SD-WAN cEdge, ACI APIC, vEdge etc.  Although the icon-library-production-oct2016 library contains a very good quality image of ACI/Switches/FW's etc it lacks the newer icons as mentioned above.
Could you advise if there is a newer version of the icon-library-production-oct2016 file.
balaji.bandi
here is new all available here (stencils)
https://www.cisco.com/c/en/us/products/visio-stencil-listing.html
BB
dave.chadwick
Visitor
BB, thanks for the prompt reply, these seem like physical product stencils rather than logical icons! Do you know if the same exists for the logical icons ?
not sure if this is what you looking, i have download long back dont remember the patch,
attached zip file check is this what you looking ?
BB
Hello BB,
I need to use these icons in my visio, do you have .vss version of it, or how to install those into visio, do you know?
BR,
Yogesh Gaikwad
