Showing results forĀ
Search instead forĀ
Did you mean:Ā
Hidden Gems in Cisco IOS: Programmability
jiangy
7 min 22 sec
Host Rich Thayer talks about programmability with Tracy Jiang, product manager, Cisco IOS.
This podcast describes actual programming inside the Cisco device - how you can program your routers and switches.
Right-click MP3 or just click Play below to listen.
rletourneau
I don't see the links to The podcast
Hi Raymond,
Here's the URL to the podcast:
http://www.cisco.com/en/US/docs/ios/tech/tdforum/iosprogrammability_HiddenGems_prog.mp3
Thanks!
Janel
jan xuan
got the links, and have downloaded the tutoral. thanks!
Sent from Cisco Technical Support Android App
