how to highlighting cisco sintax with notepad++
dotansplus
hello everyon
I tried to highlight the cisco sintax with this help:
http://www.linickx.com/875/cisco-asa-syntax-highlighting-with-notepad
But it doesn't work, someone has another option?
Thanks.
6 Replies 6
Jamesseibert11
Sorry for bumping ancient thread, but it comes up in search so figure it's worth a reply -
The original blog post was probably for an older version of NotePad++ and the xml might not be 100%.
I went in to "language -> define language", then chose to "create new" named it Cisco-Test.
I then copied the words from linickx's xml file into the words 1,2,3,4 respectively and used the styler to make my own colors.
I also added a ton of other commands from my normal configs to the different groups.
once I'm 95% happy with it I'll run an export and save on my blog to share.
Good Luck
Hi James. Did you arrive to a version that you like. Would you please share it. :) Thx
I have blogged this , i cant stress enough during troubleshooting it helps alot . as blog is down i will provide file here . Just rename file to .xml and put it in C:\Users\USER-NAME\AppData\Roaming\Notepad++ Folder ,
  • Note: you need to replace or delete other .xml file if exist & File name is case sensitive .
Edit : cisco in built uploader messed up file name it must be userDefineLang.xml
I tried it. works nice. For those who tried to search it in settings>style..
it is in languages, at the bottom there are 4 new languages named cisco. :)
Hi.
Thanks for you work.
Looks nice)))
Very help full. Thanks
