There are several Visio stencils that are missing from the library that I need. They're important to me (and I imagine others want them too) as I need to do rack elevation diagrams. I hate to open a TAC case on them but not sure what else to do. Any thoughts?
The stencils I require are:
ASA5510 (Rear view - the side with the interfaces)
ME-C6524GT-8S (Rear view - the side with the power supplies) - 24 Ethernet - 10/100/1000 interfaces + 8 Gigabit Ethernet SFP uplinks, 1 fan tray
PWR-400W-AC - 400W AC power supply for the Cisco ME 6524
PWR-400W-DC - 400W DC power supply for the Cisco ME 6524
ME-C3750-24TE-M (Rear View - the side with the power supplies) - Cisco Catalyst 3750 Metro
PWR-ME3750-AC - Cisco Catalyst 3750 Metro Switch Primary AC power supply
PWR-ME3750-DC - Cisco Catalyst 3750 Metro Switch Primary AC power supply
Cheers
Solved! Go to Solution.
Hi Stephen,
We have just completed the C6840 Visio shapes and are waiting for final review and acceptance from the product group. Please check the download page early next week. I hope to have their response by then. Once they approve, we will submit it for posting and it takes about 24 hours for the web group to post the file.
Brett Newman
Cisco Visio Production
Visimation Inc.
Hi Stephen,
We just submitted the C6800 updates to the Cisco web group for posting and should be available on the download page by 1/12/16.
Brett Newman
Visimation Inc.
Thanks Brett!
Any plans to create stencils for 9500-series. I'd need 9500-40X. There is already a comment almost a year ago, where user asked for those, but still nothing... And I thought this is your state-or-the-art LAN switching solution, but support is this bad.
Suggested corrections:
File: switches_cisco_nexus_9000.zip (downloaded from CCO today, 2016_01_14)
Stencil: N9K-C9372PX Front
#1: The stencil looks good, except the text on the front of the switch states 9372TX instead of PX.
#2: The description of the stencil, states '48p 11/0G SFP+' when it should be '48p 1/10G SFP+'
Hi Mark,
Good catch... thank you! The front label text was our mistake. The description was copy/pasted from the original data sheet that has since been corrected. We've made the changes but they won't be posted on the Visio download page until the next time we add something to the N9K Visio stencil.
Brett Newman
Visimation Inc.
Hi Brett,
Is it possible to update the Nexus 9K visio stencil with the following devices:
N9K-C93180YC-FX
N9K-C93108TC-FX
N9K-C9348GC-FXP
N9K-C9336C-FX2
N9K-C93240YC-FX2
N9K-C9364C
Brett,
Could I please request stencils for the ASR-9006 + ASR-9006-BAFFLE (basically the ASR 9006 turned sideways with the air baffle kit attached) - front and rear views.
Would also like the A9K-VSM-500 Virtual Services Module for the ASR 9000.
Thanks!
Hi Gary,
I've just sent a request to the product group. As you know, our work depends on their approval.
Brett Newman
Visimation Inc.
