NAT with Static routing and Dynamic Routing
arvindkumar446
If i configure multiple routers with different networks with static routing or OSPF or BGP and edge router interface connecting internet as IP add dhcp NAT question.JPG
How do i PAT traffic from inside to outside?
I should be able to ping internet from all the routers and pc
Any article will be helpful please find the attachment.
Ip nat inside source list 10 <wan interface> overload
Ip access-list standard 10
Permit <subet need to NAT>
As you can see above even if WAN interface get it IP via PPPoE or DHCP we can use interface itself in NAT not IP it get.
MHM
balaji.bandi
Basic thing, make sure the end device able to reach the Internet router Inside interface by pinging.
How do i PAT traffic from inside to outside?   - i take this as you looking to do NAT for the inside network to outside networks.
check basic NAT config :
https://www.balajibandi.com/?p=1796
If you are looking from outside to inside ( example if you have any web server that need to access from outside to inside (follow below guide examples)
https://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/13772-12.html
still not working, post show run from the internet router,
BB
