Which material are Cisco 2802I access points made of?
JoaoLucasMacedo
Hello. We are running some validation assessments with 2802I access points for a clean environment, but we could not find any information regarding the material composition of these devices. Precisely its external cover.
Does anyone have a idea?
Thanks a lot Flavio. You get right the point!
I have a similar question about the type of polycarbonate plastic used with the Catalyst 9163E Outdoor Access Point?
Is it the same type of plastic as used on the 2800, albeit a different colour, or different?
The reason I am asking is due to avoiding any plastic on our access points due to fire regulations. If I have the detail on the plastic then we can avoid the costs of burn testing and destroying multiple APs.
Kenny
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-2800-series-access-points/datasheet-c78-736497.html
the data sheet have link to martial and WEEE compliance
you can talk look I think this answer your Q.
