adding a node to a nodeset
a.alhamali931
Community Member
Hello all,
I have a nodeSet that was already created and now I want to add new nodes to it.
I'm doing this when the nodeset is expanded. My code goes as follows:
topo.on('beforeExpandNodeSet', (sender, nodeSet) => {
        var lanInfo = this._topologyClient.getLANInfo(nodeSet.model().getData().id);     //Fetch the information of the nodes
        for (var i: number = 0; i < lanInfo.length; i++) {
          var node = topo.addNode(lanInfo[i], undefined, nodeSet);
This doesn't seem to do it. In fact, if I go through the code of the function addNode, I find out that it doesn't have a third parameter (parentNodeSet), even though it says it does, in the documentation.
How can I add this newly-created nodes to the nodeset?
Thank you
aaikepae
aaikepae
Refer this : Adding new NodeSet
Abu
Thank you Abu
Any idea when this will be added to the formal API?
Thank you
Hi AbdulRahman AlHamali,
I already add to current develop trunk. Will release that in 3 months.
Abu
