Create a customized Node class with clickNode event handler
amd.lin01
Community Member
Hi all,
I would like to create a node. If I click or select the node, there will be a message in the console.
Here are my codes.
nx.define('MyExtendNode', nx.graphic.Topology.Node, {
    view: function(view) {
         view.content[2].events.clickNode = this._nodeClick;
         return view;
    methods: {
        init: function(options) {
            this.inherited(options);
        dispose: function() {
            this.inherited();
        _nodeClick: function(sender, event){
            console.log('node clicked')
But there is no message in console.
How could I create a customized Node class?
aaikepae
Hi Tzuche,
About your customized node class, you should do two small modification.
1. view.content[2].events.clickNode should be view.content[2].events.click
2. Because NeXt view engine will parse the view json. So you should follow the syntax of view definition. like:
view.content[2].events.click = "{#_nodeClick}"
I am thinking we should add your syntax support too. Will update that sooner.
I made an example for your reference.
http://codepen.io/NEXTSUPPORT/pen/YqONOj?editors=0010
For create customized node class, you can refer these example. Extend - > Extend Node
https://developer.cisco.com/site/neXt/discover/demo/
Abu
