Any easy way to get the right yang module based on a Cli command?
nithin.bk8
Hi ,
I find it quite difficult to find any yang module related to particular operation.I would like to know if there is any simple way to get a yang module based on a particular cli command.
Ex:     How do i  get the output using yang module based on below cli command?
Cli-->
RP/0/RP0/CPU0:Router#dir harddisk:
Mon May  8 00:10:28.134 EDT
Directory of harddisk:
    20 drwxr-xr-x 2       4096 Jul  1  2016 dumper
    17 drwxrwxrwx 5       4096 May  3 20:12 cisco_support
    16 drwxr-xr-x 2       4096 Jul  1  2016 ipodwdm_log
   173 -rwxr--r--  1   19950459 Mar  9 14:29 aib_pd_all.txt
129025 drwxr-xr-x 2       4096 Aug 14  2016 ncs5500-r611104I
   108 -rwx------ 1      57865 Feb  8 13:21 dedsdf1103jl1-02082017
   170 -rw-r--r-- 1      82771 Mar  2 19:08 show_watchdog_trace_23691.by.11.20170302-190838.xr-vm_node0_RP0_CPU0.ce860.core.txt
    33 -rwxr--r-- 1      63670 May  7 03:12 Certlab-dedsdf1011jl1-2017-05-07_03-11.bak
    39 -rwxr--r-- 1        497 Mar 19 10:09 CTS-dedsdf1103jl1-2017-03-19_14-04.ver
    38 -rwxr--r--  1 1384618 Apr 19 18:27 cleaf1_show_logging.c2
129675 drwxr-xr-x 2       4096 Apr 17 21:03 showtech-bgp-2017-Apr-17.210314.EDT
129533 drw-r--r--  2 4096 Mar 10 12:16 ATTip41875
    11 drwx------ 2      16384 Jul  1  2016 lost+found
   110 -rwx------ 1      57091 Feb  6 08:23 dedsdf1103jl1_Feb62017
129486 drwxr-xr-x 3       4096 Sep 25  2016 var
    55 -rw-r--r-- 1     117127 Apr 19 18:33 cleaf1_show_tech_arp.c2.tgz
    57 -rw-r--r-- 1      83445 Apr 19 18:34 cleaf1_show_tech_spp.c2.tgz
    52 -rwxr--r-- 1     679137 Apr 19 19:15 netio_trace.c1
    12 drwxr-xr-x 2       4096 Jul  1  2016 tftpboot
   107 -rwx------ 1      61169 Mar  1 13:17 dedsdf1003jl1-sh-run-03012017
    60 -rw-r--r-- 1      68443 Apr 19 18:38 cleaf1_show_tech_spio.c2.tgz
   104 -rwx------ 1      57202 Jan 30 11:47 dedsdf1103jl1-013017
    59 -rw-r--r--  1 1585250 Apr 19 18:37 cleaf1_show_tech_support_cef.c2.tgz
    42 -rwxr--r-- 1        497 Mar 20 09:32 CTS-dedsdf1013jl1-2017-03-20_13-28.ver
    40 -rwxr--r--  1 21001 Mar 19 10:09 CTS-dedsdf1103jl1-2017-03-19_14-04.txt
    31 -rwxr--r-- 1      20068 May  7 07:08 CTS-dedsdf1011jl1-2017-05-07_11-04.txt
    51 -rw-r--r-- 1     285261 Apr 19 17:59 show_tech_support_routing_bgp_c1.tgz
    75 drwxr-xr-x 11       4096 Apr 20 11:04 showtech
    28 -rwxr--r-- 1      63670 May  7 07:08 CTS-dedsdf1011jl1-2017-05-07_11-04.bak
   111 -rwx------ 1      57091 Feb  6 08:24 dedsdf1103jl1-sh-run-02062017
    56 -rw-r--r-- 1     774115 Mar 27 17:20 sh-tech-lpts-032717.tgz
    54 -rw-r--r-- 1     305774 Apr 19 18:32 cleaf1_show_tech_bgp.c2.tgz
    45 -rw-r--r-- 1      92160 May  7 03:13 Certlab-dedsdf1011jl1-2017-05-07_03-12.tar
    14 drwxr-xr-x 2       4096 Jul  1  2016 shutdown
   174 -rwxr--r--  1 1916414 Mar  9 14:29 show_log.txt
    26 -rwx------ 1      64830 Apr 19 13:53 04192017
    58 -rw-r--r--  1 2253950 Apr 19 18:36 cleaf1_show_tech_l2vpn_platform.c2.tgz
    96 -rw-r--r-- 1     674323 Jan 30 10:47 showtech-lpts-2017-Jan-30.104517.EST.tgz
    43 -rwxr--r-- 1      21001 Mar 20 09:33 CTS-dedsdf1013jl1-2017-03-20_13-28.txt
    44 -rwxr--r-- 1      20068 May  7 03:12 Certlab-dedsdf1011jl1-2017-05-07_03-11.txt
    32 -rwxr--r--  1 1152808960 Apr 19 13:55 6131_13i.tar
    53 -rw-r--r-- 1     528006 Apr 19 18:28 cleaf1_show_tech_evpn.c2.tgz
   162 -rwx------ 1      59988 Mar  2 15:40 dedsdf1103jl1-03022017
    13 drwxr-xr-x 2       4096 Jul  1  2016 nvram
    30 -rwxr--r-- 1        501 May  7 07:08 CTS-dedsdf1011jl1-2017-05-07_11-04.ver
    61 -rw-r--r--  1 612865 Apr 19 18:40 cleaf1_show_tech_l2vpn.c2.tgz
    15 -rw-r--r-- 1        132 Apr 19 19:22 oor_aware_process
   177 -rwxr--r--  1 145701 Mar  9 14:29 ppinfo_consumer.txt
    41 -rwxr--r-- 1      58035 Mar 20 09:32 CTS-dedsdf1013jl1-2017-03-20_13-28.bak
    63 -rwxr--r-- 1     320625 Apr 19 19:22 l2vpn_trace.txt
    37 -rwxr--r--  1 17551360 Apr 19 14:07 6131_13i-smuv2.tar
    35 -rwxr--r-- 1      57859 Mar 19 10:09 CTS-dedsdf1103jl1-2017-03-19_14-04.bak
    36 -rwxr--r-- 1        500 May  7 03:12 Certlab-dedsdf1011jl1-2017-05-07_03-11.ver
5831720 kbytes total (3941356 kbytes free)
Thank you,
Nithin
saalvare
Operational models provide a super set of the collective information provided by all show commands for a given software component.  In some cases, I agree the amount of information may feel overwhelming.  In many cases, locating the operational data is pretty straight forward.  Here are some examples that look to replication show commands using YDK.  You may find them useful.
https://git.io/vSGyX
https://git.io/v9x5R
https://git.io/v9x5r
I have some additional examples for LDP, RIB and BGP that I hope to post in a few weeks.  HTH.
saalvare
