BGP Oper Path error
crench92
>>> from ydk.providers import NetconfServiceProvider
>>> from ydk.services import CRUDService
>>> from ydk.models.cisco_ios_xe import Cisco_IOS_XE_bgp_oper as bgp_oper
>>> provider = NetconfServiceProvider(address="192.168.229.250",port=10000,username="admin",password="admin")
>>> crud = CRUDService()
>>> bgp_oper = bgp_oper.BgpStateData.Neighbors()
>>> bgp_oper
<ydk.models.cisco_ios_xe.Cisco_IOS_XE_bgp_oper.Neighbors object at 0x7f8a7eb7b110>
>>> crud.read(provider,bgp_oper)
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "/usr/lib64/python2.7/site-packages/ydk/errors/error_handler.py", line 112, in helper
    return func(self, provider, entity, *args, **kwargs)
  File "/usr/lib64/python2.7/site-packages/ydk/services/crud_service.py", line 35, in read
    return self._crud.read(provider, read_filter)
  File "/usr/lib64/python2.7/contextlib.py", line 35, in __exit__
    self.gen.throw(type, value, traceback)
  File "/usr/lib64/python2.7/site-packages/ydk/errors/error_handler.py", line 82, in handle_runtime_error
    _raise(_exc)
  File "/usr/lib64/python2.7/site-packages/ydk/errors/error_handler.py", line 56, in _raise
    raise exc
ydk.errors.YPYInvalidArgumentError:  Path is invalid: Cisco-IOS-XE-bgp-oper:bgp-state-data/neighbors
Anyone have any idea what I'm doing wrong here?  I think I have the path correct according to this:
http://ydk.cisco.com/py/docs/gen_doc_ed0e7f5cd40f3bc80e0adca92a7c5a80bb92a26f.html#ydk.models.cisco_ios_xe.Cisco_IOS_XE_…
I'm able to reproduce your issue on XE 16.5.1. It appears YDK (via libyang) has detected there has been a backward incompatible change in the yang model Cisco-IOS-XE-bgp-oper.yang between XE 16.6.1 and 16.5.1
#sh ve
Cisco IOS XE Software, Version 16.05.01b
Cisco IOS
Software [Everest], Virtual XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.5.1b, RELEASE SOFTWARE (fc1)
The latest ydk XE bundle is generated for 16.6.1. YDK APIs are purely based on the yang models. So, when a model contains a backward incompatible change, you get such an error. To fix this, you need to generate & use the XE 16.5.1 YDK bundle.
pip uninstall ydk-models-cisco-ios-xe
git clone https://github.com/ciscodevnet/ydk-gen.git -b 0.6.1
cd ydk-gen
./generate --bundle profiles/bundles/cisco-ios-xe_16_5_1.json
pip install gen-api/python/cisco_ios_xe*/dist/ydk*.tar.gz
The incompatible change in the models can be seen here:
  1. yang/Cisco-IOS-XE-bgp-oper.yang at master · YangModels/yang · GitHub
  2. yang/Cisco-IOS-XE-bgp-oper.yang at master · YangModels/yang · GitHub
7 Replies 7
abhirame
Hi Brandon,
It looks like you are passing a non-top level container to the crud service. For ydk >0.6.0, when using CRUDService and other services, using a child container or list, which is not the top-level node in a yang model is no longer supported.
For example:
... # connect to provider etc
neighbors = bgp_oper.BgpStateData.Neighbors()
crud.read(provider, neighbors)
now has to be changed to:
bgp_state = bgp_oper.BgpStateData()
crud.read(provider, bgp_state)
If you try the above, it should work
This backward incompatibility has now been noted in the release notes (https://github.com/CiscoDevNet/ydk-py/releases/tag/0.6.0).
same error:
Python 2.7.5 (default, Nov  6 2016, 00:28:07)
[GCC 4.8.5 20150623 (Red Hat 4.8.5-11)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> neighbors = bgp_oper.BgpStateData()
NameError: name 'crud' is not defined
    _raise(_exc)
    raise exc
Can you enable logging <http://ydk.cisco.com/py/docs/guides/introduction.html#logging> before doing the crud.read() and post the logs?
Also, can you verify if your device support this yang model (it should be documented / advertise it in netconf capabilities)?
[root@HTENNOCDDAT01 ~]# python3.6
Python 3.6.2 (default, Jul 18 2017, 22:59:34)
>>> from ncclient import manager
>>> HOST = '192.168.229.250'
>>> PORT = 10000
>>> USER = 'admin'
>>> PASS = 'admin'
>>> with manager.connect(host=HOST, port=PORT, username=USER, password=PASS, hos                    tkey_verify=False,device_params={'name':'default'}, look_for_keys=False, allow_agent=False) as m:
...     for capability in m.server_capabilities:
...             print(capability.split('?')[0])
(output cut)
http://cisco.com/ns/yang/Cisco-IOS-XE-bgp-oper
>>> import logging
>>> log = logging.getlogger('ydk')
AttributeError: 'module' object has no attribute 'getlogger'
>>> log = logging.getLogger('ydk')
>>> log.setLevel(logging.INFO)
>>> handler = logging.StreamHandler()
>>> log.addHandler(handler)
Executing CRUD read operation
Libyang ERROR: Schema node not found. Path: '/Cisco-IOS-XE-bgp-oper:bgp-state-data'
Path 'Cisco-IOS-XE-bgp-oper:bgp-state-data' is invalid
    _raise(_exc)
    raise exc
>>> exit()
Disconnected from device
[root@HTENNOCDDAT01 ~]# pip list | grep ydk
ydk (0.6.1)
ydk-models-cisco-ios-xe (16.6.1.post1)
ydk-models-cisco-ios-xr (6.3.1)
ydk-models-ietf (0.1.4)
ydk-models-openconfig (0.1.4)
Seems to be an issue with Libyang
#sh ve
Cisco IOS
cd ydk-gen
I would like to add that I needed the following modules installed as well:
pip install gitpython
pip install pyang
pip install rstr
pip install jinja2
I also needed to add ".py" to the end of ./generate on line 4 of the solution
I now have the following error:
[root@HTENNOCDDAT01 ydk-gen]# ./generate.py --bundle profiles/bundles/cisco-ios-xe_16_5_1.json
  File "./generate.py", line 369, in <module>
    options.one_class_per_module).generate(options.bundle))
  File "/root/ydk-gen/ydkgen/__init__.py", line 91, in generate
    return self._generate_bundle(description_file)
  File "/root/ydk-gen/ydkgen/__init__.py", line 117, in _generate_bundle
    packages = self._get_packages(curr_bundle.resolved_models_dir)
  File "/root/ydk-gen/ydkgen/__init__.py", line 163, in _get_packages
    packages = ApiModelBuilder(self.iskeyword, self.language).generate(modules)
  File "/root/ydk-gen/ydkgen/builder/_api_model_builder.py", line 70, in generate
    self._resolve_expanded_cross_references(package)
  File "/root/ydk-gen/ydkgen/builder/_api_model_builder.py", line 147, in _resolve_expanded_cross_references
    self._resolve_expanded_cross_references(owned_element)
  File "/root/ydk-gen/ydkgen/builder/_api_model_builder.py", line 131, in _resolve_expanded_cross_references
    if not hasattr(identity_ref_type.i_type_spec.base.i_identity, 'i_class'):
AttributeError: 'NoneType' object has no attribute 'i_identity'
EDIT:
I resolved this issue from feedback in this thread - Help needed debugging API compilation errors from ydk-gen by uninstalling pyang1.7 and installing pyang1.6
Glad  you got it to work.  Let me clarify that the README file has the instructions to intsall the requirements using:
$ pip install -r requirements.txt
The requirements are documented at:
ydk-gen/requirements.txt at master · CiscoDevNet/ydk-gen · GitHub
Some of the packages you referenced are actually optional.  If you think the requirements file is missing packages, please let us know. Thanks.
