BGP single prefix retrieval using netconf/yang
thanhuwng
Hi, I'm looking to get detail of a BGP prefix on IOS-XR router using netconf/yang similar to what the CLI "show bgp 1.1.1.1/32" achieves. So far I can't do that.
If I use the filter below
<bgp xmlns="http://cisco.com/ns/yang/Cisco-IOS-XR-ipv4-bgp-oper">
<instances>
  <instance>
   <instance-name>default</instance-name>
    <instance-active>
     <default-vrf>
      <afs>
       <af>
        <af-name>ipv4-unicast</af-name>
        <networks>
         <network>
          <network>1.1.1.1/32<network/>
         <network>
        </networks>
       </af>
      </afs>
     </default-vrf>
    </instance-active>
   </instance>
</instances>
</bgp>
I get back all BGP ipv4 prefixes without detail on them.
<instances>
  <instance>
    <instance-active>
     <default-vrf>
      <afs>
       <af>
        <networks>
        </networks>
       </af>
      </afs>
     </default-vrf>
    </instance-active>
   </instance>
</instances>
</bgp>
I get all prefixes with detail of them.
Is there a way to retrieve detail of a single BGP prefix?
thanks
Hung
saalvare
The network filter currently needs full key specification as shown below.  We have a ddts (CSCvf05647)  to support prefix filter with partial key in request.
<rpc message-id="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <get>
    <filter type="subtree">
        <instances>
          <instance>
            <instance-active>
<default-vrf>
              <afs>
               <af>
<networks>
<network>
<rd>0000000000000000</rd>
<network>192.168.28.5</network>
<prefix-length>32</prefix-length>
<af-name>ipv4</af-name>
<process-instance-id>0</process-instance-id>
</network>
</networks>
               </af>
</afs>
</default-vrf>
            </instance-active>
          </instance>
        </instances>
      </bgp>
    </filter>
  </get>
abhirame
We have asked the responsible team about this and will get back to you shortly.
saalvare
  <get>
        <instances>
          <instance>
            <instance-active>
<default-vrf>
              <afs>
               <af>
<networks>
<network>
</network>
</networks>
               </af>
</afs>
</default-vrf>
            </instance-active>
          </instance>
        </instances>
      </bgp>
    </filter>
  </get>
Thanks Santiago. I couldn't get the full key spec filter to work, but understand there's a pending DDTS to make the partial key work so will wait until the fix is available.
thanks
Hung
