Can't set leaf-based attribute value using YLeaf instance
aligang1988
HI !
Here  http://ydk.cisco.com/py/docs/api/types.html#ydk.types.YLeaf   found information,that such class as YLeaf actually exists within ydk.
Semantics of YLeaf is to be a reflection of yang-leaf data-type within YDK.
I decided to perform some test
1. In this  piece of code value of leaf-meaning attribute is set using str-type object (set_leaf_using_str_type_object.py). This approach   is proven to be functional, simple and demonstrated in all examples I just can remember, but has one drawback. yfilter is not applicable
2.  Here  i tried to set  value of leaf-meaning attribute  using YLeaf-type object (set_leaf_using_yleaf_type_object.py). But execution failes with:
root@YDK072:~/trash# python set_leaf_using_yleaf_type_object.py
Traceback (most recent call last):
  File "set_leaf_using_yleaf_type_object.py", line 28, in <module>
    ge000.name = leaf_instance
  File "/usr/local/lib/python2.7/dist-packages/ydk/models/junos/configuration.py", line 1203298, in __setattr__
    self._perform_setattr(Configuration.Interfaces.Interface, ['name', 'apply_groups', 'apply_groups_except', 'description', 'disable', 'passive_monitor_mode', 'no_keepalives', 'traps', 'no_traps', 'interface_mib', 'no_interface_mib', 'accounting_profile', 'per_unit_scheduler', 'no_per_unit_scheduler', 'shared_scheduler', 'l2tp_maximum_session', 'schedulers', 'dce', 'vlan_tagging', 'stacked_vlan_tagging', 'flexible_vlan_tagging', 'native_vlan_id', 'speed', 'mtu', 'link_mode', 'encapsulation', 'mac', 'shared_interface', 'gratuitous_arp_reply', 'no_gratuitous_arp_reply', 'no_gratuitous_arp_request', 'no_no_gratuitous_arp_request'], name, value)
  File "/usr/local/lib/python2.7/dist-packages/ydk/types/py_types.py", line 416, in _perform_setattr
    super(Entity, self).__setattr__(name, value)
  File "/usr/lib/python2.7/contextlib.py", line 35, in __exit__
    self.gen.throw(type, value, traceback)
  File "/usr/local/lib/python2.7/dist-packages/ydk/errors/error_handler.py", line 95, in handle_type_error
    _raise(_exc)
  File "/usr/local/lib/python2.7/dist-packages/ydk/errors/error_handler.py", line 56, in _raise
    raise exc
ydk.errors.YModelError: set(): incompatible function arguments. The following argument types are supported:
    1. (self: ydk_.types.YLeaf, value: int) -> None
    2. (self: ydk_.types.YLeaf, value: int) -> None
    3. (self: ydk_.types.YLeaf, value: int) -> None
    4. (self: ydk_.types.YLeaf, value: int) -> None
    5. (self: ydk_.types.YLeaf, value: int) -> None
    6. (self: ydk_.types.YLeaf, value: int) -> None
    7. (self: ydk_.types.YLeaf, value: float) -> None
    8. (self: ydk_.types.YLeaf, value: ydk_.types.Empty) -> None
    9. (self: ydk_.types.YLeaf, value: ydk_.types.Identity) -> None
    10. (self: ydk_.types.YLeaf, value: ydk_.types.Bits) -> None
    11. (self: ydk_.types.YLeaf, value: unicode) -> None
    12. (self: ydk_.types.YLeaf, value: ydk_.types.Enum.YLeaf) -> None
    13. (self: ydk_.types.YLeaf, value: ydk_.types.Decimal64) -> None
Q: Is it expected behavior, that  YLeaf type object  can not be used as value for leaf-meaning attribute ?
    Is there any other options to define netconf operation (replace,delete, etc) for leaf data-structure  ?
Thanks !
Any of the YFilter options can be used with leafs.
Following the above example, something like the below should work
# Set a dummy value to the leaf
cdp.timer = 5
# Assign YFilter.replace to the 'timer' leaf
cdp.timer = YFilter.replace
abhirame
Please refer to the developer guide which has some example for this. You may want to use YFilter for netconf operations. YLeaf is just used internally to represent leafs and is not intended to be used by end user
http://ydk.cisco.com/py/docs/api/filters.html
http://ydk.cisco.com/py/docs/guides/crud_guide.html
Is my understanding right, that currently leaf value may be assigned with delete/remove nc:operation tag only?
In this case  leaf_like  object attributes  are assigned  with YFilter class object, as it explained here http://ydk.cisco.com/py/docs/guides/crud_guide.html#deleting-a-leaf ?
Another type of operations (such as create, merge, replace ) may not be specified  directly for leaf_like attribute, because it based on standard python datatypes (int,bool, str), which have no .yfilter attribute. Such operation tags only may be inherited from parent configuration block (list, leaf-list, container), which are based on ydk specific datatypes and have .yfilter attribute.
cdp.timer = 5
Yes, it works in the way you previously explained !
Thanks !
