YDK 0.7.1 - Couldn't fetch child entity interface in parent /ietf-interfaces:interfaces-state!
m.m.mazurek
I am trying to run linuxcfg example from confd-basic (6.3 and not newer a YDK doesn't support YANG 1.1 - python classes generation fails).
NETCONF query works just fine and returns as expected a list of interfaces (as this is what I am asking for).
interfacesState = InterfacesState()
interfacesState = crud.read(provider, interfacesState)
When read wants to build InterfacesState() object it fails as below:
Looking at parent entity interfaces-state
Looking at child list '/ietf-interfaces:interfaces-state/interface[name='lo']'
Going into child interface in parent /ietf-interfaces:interfaces-state
Traceback (most recent call last):
  File "/home/ydk_user/PycharmProjects/ydk/linuxcfg.py", line 29, in <module>
  File "/home/ydk_user/.local/lib/python2.7/site-packages/ydk/services/crud_service.py", line 63, in read
    read_entity = self._crud.read(provider, filters)
  File "/usr/lib/python2.7/contextlib.py", line 35, in __exit__
    self.gen.throw(type, value, traceback)
  File "/home/ydk_user/.local/lib/python2.7/site-packages/ydk/errors/error_handler.py", line 82, in handle_runtime_error
    _raise(_exc)
  File "/home/ydk_user/.local/lib/python2.7/site-packages/ydk/errors/error_handler.py", line 56, in _raise
    raise exc
ydk.errors.YCoreError:  Couldn't fetch child entity 'interface' in parent /ietf-interfaces:interfaces-state
Disconnected from device
Trace: Writing message (session 17): <?xml version="1.0" encoding="UTF-8"?>
<rpc xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="3">
  <close-session/>
</rpc>
Issue is in function (py_types.py) which shows that _children_name_map attribute of InterfaceState is basically empty and cannot fetch any children:
    def _get_child_by_seg_name(self, segs):
        for seg in segs:
            for name in self._children_name_map:
                if seg == self._children_name_map[name]:
                    return self.__dict__[name]
        return None
Br,
M
Got it. I was trying the pre-generated package from pypi.
Can you try running the 'generate.py' again after checking out the '0.7.1' tag of ydk-gen? Please uninstall the previous package and use the package generated with this.
cd ydk-gen
git checkout 0.7.1
./generate.py...
abhirame
I'm not able to reproduce the issue with the below environment
> pip list|grep ydk
ydk (0.7.1)
ydk-models-ietf (0.1.5)
I took raw Yang models from confd6.3 and generated classes with ydk-gen. Have you done the same?
cd ydk-gen
git checkout 0.7.1
./generate.py...
Thank you - have you made some changes to the code ? I did the installation as follows:
wget https://devhub.cisco.com/artifactory/debian-ydk/0.7.1/libydk_0.7.1-1_amd64.deb
