Conditionally change Node Label offset
ben-redfern
Community Member
Hi All,
I have a custom icon registered and working (it's size is wider and has less height - 48 x 16).
My question is whether it's possible to change the x & y label offsets ONLY for nodes with that icon?
My investigations so far seem to point this being controlled by Node.js->content->view->props->y value but I am not sure how to conditionally set this for the node subset.
Any Help greatly appreciated.
Many Thanks
Ben
alzverev
Hi Ben,
I would recommend to use standard size for all objects, but I went ahead and prepared an example for you: http://codepen.io/NEXTSUPPORT/pen/dXBdzK?editors=0010
The code extends the node class by overriding the implementation of "calcLabelPosition" method.
Should you have a question - I'm here to help.
Alex
