Custom RPC
k.rohini
Community Member
1. I want to write a custom rpc for my module.. I am not able to understand where to write the code specific to the rpc..
2. Is it possible to execute the samples on a linux enviroment?
saalvare
Regarding your first quesion, the executor service is used to excute custom RPCs.  See the documentation at:
http://ydk.cisco.com/py/docs/ydk.services.html#executorservice-provides-api-to-execute-rpcs
The RPCs must be defined in YANG.  Cisco IOS XR supports a growing number of custom RPCs.  You can find sample apps for the executor service at:
https://github.com/CiscoDevNet/ydk-py-samples/tree/master/samples/basic/executor/models
Regarding the second question, we support Linux (debian and RPM-based).  You can find the YDK installation instructions at:
http://ydk.cisco.com/py/docs/getting_started.html#linux
Once you install YDK, you can clone the YDK-Py samples repo and run the apps against any XR or OC compatible device:
Thanks.
saalvare
Thanks.
