devtoolset-4-gcc* not available for CentOS 7.9
shreyash
Hi ,
I am using a Centos 7.9 server.
When I try to install gcc as per the system requirements mentioned here http://ydk.cisco.com/py/docs/getting_started.html#system-requirements, I am facing
No package devtoolset-4-gcc* available
root@cafy-2:shreyash$ sudo yum install devtoolset-4-gcc*
Loaded plugins: fastestmirror, langpacks, product-id, search-disabled-repos, subscription-manager
This system is not registered with an entitlement server. You can use subscription-manager to register.
Loading mirror speeds from cached hostfile
 * base: mirror.datto.com
 * centos-sclo-rh: repo.ialab.dsu.edu
 * centos-sclo-sclo: mirrors.vcea.wsu.edu
 * extras: ftpmirror.your.org
 * updates: ftpmirror.your.org
No package devtoolset-4-gcc* available.
Error: Nothing to do
Could you please help here.
The documentation under ydk.cisco.com references YDK release 0.8.3, which is significantly outdated. I strongly suggest you to move to the latest publicly available release 0.8.5.2, which you can find here. It includes YDK installation script, which will take care of all the dependencies needed for your CentOS-7.9 platform.
Yan Gorelik
YDK Solutions
5 Replies 5
balaji.bandi
The first try is there any packages available with that name  :
sudo yum search devtoolset |grep devtoolset|awk {'print $1'} |cut -f 1,2 -d\-|sort|uniq
BB
The version devtoolset4 mentioned in the system requirements http://ydk.cisco.com/py/docs/getting_started.html#system-requirements is not there
root@cafy-2:shreyash$ sudo yum search devtoolset |grep devtoolset|awk {'print $1'} |cut -f 1,2 -d\-|sort|uniq
devtoolset-10
devtoolset-10.x86_64
devtoolset-7
devtoolset-7.x86_64
devtoolset-8
devtoolset-8.x86_64
devtoolset-9
devtoolset-9.x86_64
Could you update the systems requirements document  http://ydk.cisco.com/py/docs/getting_started.html#system-requirements with the available version please
Yan Gorelik
YDK Solutions
Thanku
