Difference in deleting static route on XR between 0.5.1 and 0.7.0
dvulovic
Below is the simple Python code that should deletes static route on IOS XR:
    def create_RouterStatic_obj(arg_prefix,arg_prefixlen,arg_nexthop):
        router_static = Cisco_IOS_XR_ip_static_cfg.RouterStatic()
        vrf_unicast = router_static.default_vrf.address_family.vrfipv4.vrf_unicast
        vrf_prefix = vrf_unicast.vrf_prefixes.VrfPrefix()
        vrf_prefix.prefix = arg_prefix
        vrf_prefix.prefix_length = arg_prefixlen
        vrf_next_hop_next_hop_address = vrf_prefix.vrf_route.vrf_next_hop_table.VrfNextHopNextHopAddress()
        vrf_next_hop_next_hop_address.next_hop_address = arg_nexthop
        vrf_prefix.vrf_route.vrf_next_hop_table.vrf_next_hop_next_hop_address.append(vrf_next_hop_next_hop_address)
        vrf_unicast.vrf_prefixes.vrf_prefix.append(vrf_prefix)
        return router_static
    def delete_static_route(arg_prefix,arg_prefixlen,arg_nexthop):
        router_static = create_RouterStatic_obj(arg_prefix,arg_prefixlen,arg_nexthop)
        xr.ydk_crud.delete(xr.ydk_provider, router_static.default_vrf.address_family.vrfipv4.vrf_unicast.vrf_prefixes.vrf_prefix[0])
On YDK 0.5.1 it worked correctly, with following NETCONF message being sent:
<rpc xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="urn:uuid:88ecc19c-3c07-4bb7-945d-cae4f3c1c810">
  <edit-config>
    <target>
      <candidate/>
    </target>
    <config xmlns:xc="urn:ietf:params:xml:ns:netconf:base:1.0">
      <router-static xmlns="http://cisco.com/ns/yang/Cisco-IOS-XR-ip-static-cfg">
        <default-vrf>
          <address-family>
            <vrfipv4>
              <vrf-unicast>
                <vrf-prefixes>
                  <vrf-prefix xc:operation="delete">
                    <prefix>13.11.11.0</prefix>
                    <prefix-length>24</prefix-length>
                    <vrf-route>
                      <vrf-next-hop-table>
                        <vrf-next-hop-next-hop-address>
                          <next-hop-address>100.100.100.100</next-hop-address>
                        </vrf-next-hop-next-hop-address>
                      </vrf-next-hop-table>
                    </vrf-route>
                  </vrf-prefix>
                </vrf-prefixes>
              </vrf-unicast>
            </vrfipv4>
          </address-family>
        </default-vrf>
      </router-static>
    </config>
  </edit-config>
</rpc>
However, on YDK 7.0 it deletes all static routes. Message sent reveals that "delete" is now in the <router-static> level:
<rpc xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<edit-config xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <target>
    <candidate/>
  </target>
  <error-option>rollback-on-error</error-option>
  <config><router-static xmlns="http://cisco.com/ns/yang/Cisco-IOS-XR-ip-static-cfg" xmlns:nc="urn:ietf:params:xml:ns:netconf:base:1.0" nc:operation="delete">
  <default-vrf>
    <address-family>
      <vrfipv4>
        <vrf-unicast>
          <vrf-prefixes>
            <vrf-prefix>
              <vrf-route>
              </vrf-route>
            </vrf-prefix>
          </vrf-prefixes>
        </vrf-unicast>
      </vrfipv4>
    </address-family>
  </default-vrf>
</router-static>
</config>
</edit-config>
</rpc>
Is this a bug in YDK-Py or client code should be changed?
abhirame
The client code needs to be changed. Please see this example for how to delete lists in YDK 0.7.+ :
http://ydk.cisco.com/py/docs/guides/crud_guide.html#deleting-a-list
