drawing vlanPaths that works with nodeSet
kevinche
I have a topology that uses "Nodeset".  I am drawing paths (for example, VlanPath) on top of the topology when user selects the vlans.
When I collapse the Nodesets, the vlanpaths remain on screen not collapsing with the Nodeset.   Is there a way to make Nodeset aware of the vlanPaths when collapsing/expanding?
FYI, I don't need to draw the vlanPath from node to the nodeset when it is collapsed if that makes my life easier.
The vlanpath is extended like this:
nx.define('IND.VlanPath', nx.graphic.Component, {
properties:{...},
view:{ type: 'nx.graphic.Group',
                content: [{
                    type: 'nx.graphic.Path',
                    props: {
                        'fill': 'none',
                        'stroke-width': '10px',
                        'stroke-dasharray': '4,0.8'
methods:{...}
I setup a custom layer
nx.define("IND.VlanLayer", nx.graphic.Topology.Layer, {
properties:{...},
methods:{...}
I setup the layer like this:
sender.insertLayerAfter("vlan", "IND.VlanLayer", "linkSet");
                    this.view('topo').graph().on("updateVertexCoordinate", function (sender, vertex) {
                        this.view('topo').getLayer("vlan")._draw();
                    }, this);
0 Replies 0
