Error Running YDK
brfoster
I have set up a new YDK 0.4.2 environment and I am trying to run the sample YDK python script.  I'm seeing an error...
(ydk-py) [gibson@rickenbacker ydk-py]$ python2.7 ./samples/bgp.py -h
Traceback (most recent call last):
  File "./samples/bgp.py", line 32, in <module>
    from ydk.models.bgp.bgp_types import Ipv4Unicast_Identity
ImportError: cannot import name Ipv4Unicast_Identity
After inspecting the bgp_types.py file I can see that Ipv4Unicast_Identity *should be* Ipv4UnicastIdentity (no underscore).
Now it runs fine...
Usage: bgp.py [-h | --help] [options]
Options:
  -h, --help            show this help message and exit
  -v VERSION, --version=VERSION
                        force NETCONF version 1.0 or 1.1
  -u USERNAME, --user=USERNAME
  -p PASSWORD, --password=PASSWORD
                        password
  --proto=PROTO         Which transport protocol to use, one of ssh or tcp
  --host=HOST           NETCONF agent hostname
  --port=PORT           NETCONF agent SSH port
abhirame
Thanks. Both the above issues have been fixed
abhirame
Thanks for letting us know about this . This sample will be fixed to remove this error.
Also Ipv6Unicast_Identity should be Ipv6UnicastIdentity.
abhirame
