Error when creating OSPF-cfg
yitung
When I create the ospf process, it shows the following error:
        error-type: application
        error-tag: operation-failed
        error-severity: error
        error-path: ns1:ospf/ns1:processes/ns1:process[process-name = 'DEFAULT']/ns1:default-vrf/ns1:area-addresses/ns1:area-area-id[area-id = '1']/ns1:name-scopes/ns1:name-scope[interface-name = 'GigabitEthernet0/0/0/1']/ns1:network-type
        error-message: 'CfgMgr' detected the 'fatal' condition 'This configuration has not been verified and can not be accepted by the system.'
The way I workaround it is to create "router ospf DEFAULT" via CLI in XR first... Is it a kind of a bug or if I miss some steps??
Please find the full log in the attachment.
After creating "router ospf DEFAULT" via CLI:
RP/0/0/CPU0:R1#show run router ospf
Wed Dec 21 14:39:34.488 UTC
router ospf DEFAULT
RP/0/0/CPU0:R1#
Detail log in the attachment.
yitung
Just try and error and found that I need to add "process.start = empty()" to create the OSPF process from scratch.
def config_ospf(ospf):
    """Add config data to ospf object."""
    # OSPF process
    process = ospf.processes.Process()
    process.process_name = "DEFAULT"
    process.default_vrf.router_id = "10.2.11.1"
#    process.nsr = xr_ipv4_ospf_cfg.NsrEnum.TRUE
    process.start = Empty()                       <<<<<<<<<<<<<<<<<
