Found empty data tag, meaning requested data are not found on Netconf server
MahdiR
Trying to retrieve information from an interface gives me the following error:
I know that the information exists in the box, but it seems like Netconf cannot see the data!
I've read the logger output but still doesn't know what is wrong. Will appreciate any help.
I've attached the output from the logger.
Here is my code:
import logging
import ydk.models.ietf.ietf_interfaces as ietf_ifc
from ydk.services.netconf_service import NetconfService, Datastore
from ydk.providers.netconf_provider import NetconfServiceProvider
def enable_logging(level):
    log = logging.getLogger('ydk')
    log.setLevel(level)
    handler = logging.StreamHandler()
    formatter = logging.Formatter(
        "%(asctime)s - %(name)s - %(levelname)s - %(message)s")
    handler.setFormatter(formatter)
    log.addHandler(handler)
if __name__ == "__main__":
    enable_logging(logging.DEBUG)
    service = NetconfService()
    provider = NetconfServiceProvider(address=address,
                                      username=username,
                                      password=password,
                                      port=830)
    model = ietf_ifc.InterfacesState()
    ifc = ietf_ifc.InterfacesState.Interface()
    ifc.name = "TenGigabitEthernet1/3"
    model.interface.append(ifc)
    result = service.get(provider, model)
    print(result)
yangorelik
Hi Mahdi
Indeed your request did not return any data and therefore the INFO message:
2020-11-12 07:45:33,174 - ydk - INFO - ============= Received RPC from device =============
<?xml version="1.0" encoding="UTF-8"?>
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="1">
<data/>
</rpc-reply>
2020-11-12 07:45:33,174 - ydk - INFO - Found empty data tag, meaning requested data are not found on Netconf server
None
Most likely the interface name is incorrect or the interface is not configured. Get all interfaces by dropping specific one in the object building, then run your script with the matching specific interface name. If you still get the empty data tag, consult device software engineers.
Yan Gorelik
YDK Solutions
yangorelik
Hi Mahdi
<data/>
</rpc-reply>
None
Yan Gorelik
YDK Solutions
Removing the filter yields the same result!
Might be something wrong with Netconf configuration on the device as you suggest.
Thanks for the help
