Get stuck when running ydk-py hello world sample
ElvisLou15831
Hi guys, I am new to cisco router and ydk.
I have a problem need your help.
env:
IOS XRv 9000 virtual Router
ydk-code:
from ydk.services import CRUDService
        from ydk.providers import NetconfServiceProvider
        from ydk.models.cisco_ios_xr import Cisco_IOS_XR_shellutil_oper \
            as xr_shellutil_oper
        from datetime import timedelta
        if __name__ == "__main__":
            """Main execution path"""
            # create NETCONF session
            provider = NetconfServiceProvider(address="10.0.0.1",
                                              port=830,
                                              username="admin",
                                              password="admin",
                                              protocol="ssh")
            # create CRUD service
            crud = CRUDService()
            # create system time object
            system_time = xr_shellutil_oper.SystemTime()
            # read system time from device
            system_time = crud.read(provider, system_time)
            # Print system time
            print("System uptime is " +
                  str(timedelta(seconds=system_time.uptime.uptime)))
            # close NETCONFIG session and exit
            provider.close()
            exit()
What I observed is that the code is stucking at the line "system_time = crud.read(provider, system_time)"
no error printed in log,
what can i do now? thanks. please point out if need more context.
5 Replies 5
MahdiR
Try adding this to your code. It will give you information about the problem.
import logging
log_ydk = logging.getLogger('ydk')
log_ydk.setLevel(logging.DEBUG)
handler = logging.StreamHandler()
log_ydk.addHandler(handler)
yangorelik
Also check if Netconf server is configured on your virtual router and you can run CLI to it:
ssh admin@10.0.0.1 -p 830 -s netconf
 Afer  entering password you are expected to get Netconf server capabilities.
Yan Gorelik
YDK Solutions
Hi yangorelik,thanks for the reply.
Now I can use the YDK api to read the system time from the router and call other api to do some operation.
but i am not sure if the operation is successful or not ?
is there anywhere in the router can have the log which i can check?
Thanks very much.
Good day ElvisLou,
Not sure if I fully understand what you mean, but the logging I have in my code is done this way:
log = logging.getLogger('ydk')
log.setLevel(level)
formatter = logging.Formatter("%(asctime)s - %(name)s - %(levelname)s - %(message)s")
handler.setFormatter(formatter)
log.addHandler(handler)
Hope that was to some help.
Kind regards,
Simon Johansen
Hi Elvis
To check if operation was successful you need to use YDK API. For example (see CRUDService API
            if system_time:
print("System uptime is " + str(timedelta(seconds=system_time.uptime.uptime)))
else:
print("Failed to read system time")
You also can catch runtime exceptions:
try: system_time = crud.read(provider, system_time) if system_time:
else:
except YError as err:
print("Exception occurred during crud.read operation: %s" % err.message)
In general it is good programming practice to handle in the application all available runtime errors.
Yan Gorelik
YDK Solutions
