How to configure SR mappings
saalvare
SR mappings are required to connect SR devices with other MPLS devices using LDP.  Here are five sample apps to configure IPv4 and IPv6 mappings:
nc-create-xr-segment-routing-ms-cfg-20-ydk.py - mapping with single IPv4-to-SID range
nc-create-xr-segment-routing-ms-cfg-21-ydk.py - mapping with single IPv6-to-SID range
nc-create-xr-segment-routing-ms-cfg-22-ydk.py - mapping with two IPv4-to-SID ranges
nc-create-xr-segment-routing-ms-cfg-23-ydk.py - mapping with two IPv6-to-SID ranges
nc-delete-xr-segment-routing-ms-cfg-20-ydk.py - delete all mapping configuration
As usual, you can also find four boilerplate apps to start creating your own mapping configurations:
nc-create-xr-segment-routing-ms-cfg-10-ydk.py - create boilerplate
nc-read-xr-segment-routing-ms-cfg-10-ydk.py - read boilerplate
nc-update-xr-segment-routing-ms-cfg-10-ydk.py - update boilerplate
nc-delete-xr-segment-routing-ms-cfg-10-ydk.py - delete boilerplate
You can find the commit at: https://git.io/v1YPp
Try them out!
0 Replies 0
