I need help on automating openconfig-vlan.yang module
balamani
I am trying to automate "openconfig-vlan.yang" module using YDK. But i am getting error.
Below is the Script and command i used to run script "python test_vlan_config.py ssh://admin:admin@1.1.1.1:11111":
But similar script worked for cisco_ios_xr "Cisco_IOS_XR_cdp_cfg" module. for this module able create, read, write and delete.
from ydk.services import CRUDService
from ydk.providers import NetconfServiceProvider
from ydk.models.openconfig import openconfig_vlan
import logging
from argparse import ArgumentParser
from urlparse import urlparse
def config_vlan(vlan_conf):
  vlan_conf.name = "VLAN100"
   vlan_conf.status = "ACTIVE"
   vlan_conf.vlan_id = 1555
   print("*****************After Setting************")
   print(vlan_conf.name)
   print(vlan_conf.status)
   print(vlan_conf.vlan_id)
   print(vlan_conf)
def test1_vlans_func():
   if __name__ == "__main__":
   """Execute main program."""
   parser = ArgumentParser()
  parser.add_argument("-v", "--verbose", help="print debugging messages",
   action="store_true")
  parser.add_argument("device",
   help="NETCONF device (ssh://user:password@host:port)")
  args = parser.parse_args()
   device = urlparse(args.device)
   # log debug messages if verbose argument specified
   if args.verbose:
  logger = logging.getLogger("ydk")
  logger.setLevel(logging.DEBUG)
  handler = logging.StreamHandler()
  formatter = logging.Formatter(("%(asctime)s - %(name)s - "
  "%(levelname)s - %(message)s"))
  handler.setFormatter(formatter)
  logger.addHandler(handler)
   # create NETCONF session
   provider = NetconfServiceProvider(address="1.1.1.1",
   port=11111,
   username="admin",
   password="admin",
   protocol="ssh")
   # create CRUD service
   crud = CRUDService()
   # create vlnas configobject
   vlan_conf = openconfig_vlan.Vlans.Vlan.Config()
   print("###Before setting####")
   print(vlan_conf)
   # print system uptime
   print("####After returning from the function#######")
   print(vlan_conf)
   crud.create(provider, vlan_conf)
   print("####After creating crud service#######")
   print(vlan_conf)
   # close NETCONF session and exit
   provider.close()
   exit()
   # End of script
test1_vlans_func()
Error Output:
<ydk.models.openconfig.openconfig_vlan.Config object at 0x7fa1fa508590>
VLAN100
ACTIVE
1555
Traceback (most recent call last):
  File "test_vlan_config.py", line 90, in <module>
    test1_vlans_func()
  File "test_vlan_config.py", line 81, in test1_vlans_func
  File "/usr/local/lib/python2.7/dist-packages/ydk/services/crud_service.py", line 62, in create
    self._execute_crud_operation_on_provider(provider, entity, 'CREATE', False)
  File "/usr/local/lib/python2.7/dist-packages/ydk/services/crud_service.py", line 166, in _execute_crud_operation_on_provider
    only_config
  File "/usr/local/lib/python2.7/dist-packages/ydk/providers/netconf_provider.py", line 88, in encode
    return self.sp_instance.encode(entity, operation, only_config)
  File "/usr/local/lib/python2.7/dist-packages/ydk/providers/_provider_plugin.py", line 112, in encode
    root = self._encode_edit_request(root, entity, operation)
  File "/usr/local/lib/python2.7/dist-packages/ydk/providers/_provider_plugin.py", line 432, in _encode_edit_request
    root = self._create_preamble(entity, root)
  File "/usr/local/lib/python2.7/dist-packages/ydk/providers/_provider_plugin.py", line 494, in _create_preamble
    parent_meta_tuple_list = self._get_parent_tuple_list(entity, entity._meta_info())
  File "/usr/local/lib/python2.7/dist-packages/ydk/providers/_provider_plugin.py", line 590, in _get_parent_tuple_list
    self._raise_parent_hierarchy_error()
  File "/usr/local/lib/python2.7/dist-packages/ydk/providers/_provider_plugin.py", line 520, in _raise_parent_hierarchy_error
    raise YPYServiceProviderError(error_code=YPYErrorCode.INVALID_HIERARCHY_PARENT)
ydk.errors.YPYServiceProviderError: Parent is not set.                     Parent Hierarchy cannot be determined
I am completely new to YDK and data model automation. also I don't understand in detail about create and delete operation. Please help me on this.
Below are the details of YDK.
vagrant@ydk-py:test_openconfig_vlan$ pip list | grep ydk
ydk                     0.5.4
ydk-models-cisco-ios-xr 6.2.1
ydk-models-ietf         0.1.1
ydk-models-openconfig   0.1.2
Thanks & Regards,
Basavaraj
Message was edited by: Basavaraj Lamani
Basavaraj,
You also need to consider the content of the file cisco-xr-openconfig-vlan-deviations.yang when determining exactly what is supported:
https://github.com/YangModels/yang/blob/master/vendor/cisco/xr/622/cisco-xr-openconfig-vlan-deviations.yang
Cheers,
Einar
balamani
I modified the script and now i am getting different error. Please help.
import logging
  vlan_conf.Vlan.Config.name = "VLAN100"
   vlan_conf.Vlan.Config.status = "ACTIVE"
   vlan_conf.Vlan.Config.vlan_id = 1555
   print(vlan_conf.Vlan.Config.name)
   print(vlan_conf.Vlan.Config.status)
   print(vlan_conf.Vlan.Config.vlan_id)
   print(vlan_conf)
   if args.verbose:
   port=11111,
   username="admin",
   password="admin",
   protocol="ssh")
  #vlan_conf = openconfig_vlan.Vlans.Vlan.Config()
   vlan_conf = openconfig_vlan.Vlans()
   print(vlan_conf)
   print(vlan_conf)
   print(vlan_conf)
   provider.close()
   exit()
   # End of script
test1_vlans_func()
########error output###:
vagrant@ydk-py:test_openconfig_vlan$ python test_vlan_config.py ssh://admin:admin@1.1.1.1:11111 -v
2017-08-18 05:25:51,013 - ydk.providers.netconf_provider - INFO - NetconfServiceProvider connected to 10.85.104.17:20083 using ssh
<ydk.models.openconfig.openconfig_vlan.Vlans object at 0x7f71a1726650>
VLAN100
ACTIVE
1555
2017-08-18 05:25:51,020 - ydk.services.crud_service - INFO - CREATE operation initiated
2017-08-18 05:25:51,022 - ydk.providers._provider_plugin - DEBUG -
<rpc xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="urn:uuid:2021e2b8-5342-49ab-8321-56d5a84dbb64">
  <edit-config>
    <target>
      <candidate/>
    </target>
    <config xmlns:xc="urn:ietf:params:xml:ns:netconf:base:1.0">
      <vlans xmlns="http://openconfig.net/yang/vlan"/>
    </config>
  </edit-config>
</rpc>
2017-08-18 05:25:51,449 - ydk.providers._provider_plugin - DEBUG -
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="urn:uuid:2021e2b8-5342-49ab-8321-56d5a84dbb64">
  <rpc-error>
    <error-type>protocol</error-type>
    <error-tag>unknown-namespace</error-tag>
    <error-severity>error</error-severity>
    <error-info>
      <bad-element>vlans</bad-element>
      <bad-namespace>http://openconfig.net/yang/vlan</bad-namespace>
    </error-info>
  </rpc-error>
</rpc-reply>
2017-08-18 05:25:51,453 - ydk.providers._provider_plugin - ERROR -
  <edit-config>
    <target>
      <candidate/>
    </target>
    </config>
  </edit-config>
</rpc>
<?xml version="1.0"?>
<rpc-reply message-id="urn:uuid:2021e2b8-5342-49ab-8321-56d5a84dbb64" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<rpc-error>
  <error-info>
  </error-info>
</rpc-error>
</rpc-reply>
2017-08-18 05:25:51,456 - ydk.services.crud_service - INFO - CREATE operation completed
  File "test_vlan_config.py", line 91, in <module>
    test1_vlans_func()
  File "test_vlan_config.py", line 82, in test1_vlans_func
  File "/usr/local/lib/python2.7/dist-packages/ydk/services/crud_service.py", line 168, in _execute_crud_operation_on_provider
    operation
  File "/usr/local/lib/python2.7/dist-packages/ydk/services/service.py", line 36, in execute_payload
    reply = provider.execute(payload, operation)
  File "/usr/local/lib/python2.7/dist-packages/ydk/providers/netconf_provider.py", line 94, in execute
    return self.sp_instance.execute_operation(payload, operation)
  File "/usr/local/lib/python2.7/dist-packages/ydk/providers/_provider_plugin.py", line 224, in execute_operation
    return self._handle_rpc_reply(operation, payload, reply.xml)
  File "/usr/local/lib/python2.7/dist-packages/ydk/providers/_provider_plugin.py", line 246, in _handle_rpc_reply
    self._handle_rpc_error(payload, reply_str, pathlist)
  File "/usr/local/lib/python2.7/dist-packages/ydk/providers/_provider_plugin.py", line 259, in _handle_rpc_error
    raise YPYServiceProviderError(error_code=YPYErrorCode.SERVER_REJ, error_msg=reply_str)
ydk.errors.YPYServiceProviderError: Server rejected request.
        error-type: protocol
        error-tag: unknown-namespace
        error-severity: error
        bad-element: vlans
        bad-namespace: http://openconfig.net/yang/vlan
From the first error, looks like there was an issue with your script as you were not correctly populating the list. Can you try something like the below?
  vlan = openconfig_vlan.Vlan()
  vlan.vlan_id = 1555
  vlan.config.vlan_id = 1555
  vlan.config.name = "VLAN100"
  vlan.config.status = "ACTIVE"
  vlans.vlan.append(vlan)
# create vlans configobject
For the second error, looks like the device you are connecting to does not support the openconfig-vlan model.
Hi Abhirame,
Thanks for your input.
As per your suggestion i made changes but still i am getting 2nd error.
Also i checked in router whether "openconfig-vlan.yang" module supported or not by giving below commands on router.
1) "run" command
2) "cd /pkg/yang" command. This command lists all the available modules and i can see "openconfig-vlan.yang" module.
Please let me know is this correct procedure to check supported modules on router. Also let me know if i need to make any further changes in my script.
Basavaraj,
Cheers,
Einar
