YDK-Cpp installation made super simple!
abhirame
Starting with release 0.6.0, prebuilt binaries for YDK-Cpp are now part of the Artifact Repository. This means a dramatically simpler installation experience.  Instead of downloading/cloning the YDK-Cpp code, building the libraries from source code and installing them, you can just use the prebuilt binaries to automate the installation. Previously, a full installation of YDK-Cpp (YDK core package, plus XR/XE/OpenConfig/IETF) could take many more steps.
Now, taking Ubuntu as an example, to install the system dependencies and the YDK core package, issue:
$ sudo apt-get install gdebi-core libtool-bin
$ wget https://devhub.cisco.com/artifactory/debian-ydk/0.6.0/libydk_0.6.0-1_amd64.deb
$ sudo gdebi libydk_0.6.0-1_amd64.deb
Then, to install the IETF bundle package, issue:
$ wget https://devhub.cisco.com/artifactory/debian-ydk/0.6.0/libydk-ietf_0.1.3-1_amd64.deb
$ sudo gdebi libydk-ietf_0.1.3-1_amd64.deb
Then, to install the OpenConfig bundle package, issue:
$ wget https://devhub.cisco.com/artifactory/debian-ydk/0.6.0/libydk-openconfig_0.1.3-1_amd64.deb
$ sudo gdebi libydk-openconfig_0.1.3-1_amd64.deb
Then, to install the Cisco-IOS-XR bundle package, issue:
$ wget https://devhub.cisco.com/artifactory/debian-ydk/0.6.0/libydk-cisco-ios-xr_6.2.2-1_amd64.deb
$ sudo gdebi libydk-cisco-ios-xr_6.2.2-1_amd64.deb
Then, to install the Cisco-IOS-XE bundle package, issue:
$ wget https://devhub.cisco.com/artifactory/debian-ydk/0.6.0/libydk-cisco-ios-xe_16.6.1-1_amd64.deb
$ sudo gdebi libydk-cisco-ios-xe_16.6.1-1_amd64.deb
That's it. That simple!
Note that you still need to install some of the system dependencies for your specific OS platform the first time you use YDK-Cpp. See our updated quick installation instructions in the README.
Also, you can browse all the available YDK-Cpp packages for 0.6.0 at the below links:
Let's get developing!
0 Replies 0
