Installation problems ydk-gen
Rob85
I'm trying to install this package but I receive an error.
I've created a virtual env for this:
(py2) rob@ubuntu:ydk-gen$ pip list
alabaster (0.7.10)
Babel (2.4.0)
docutils (0.14)
gitdb (0.6.4)
GitPython (1.0.1)
imagesize (0.7.1)
Jinja2 (2.9.6)
MarkupSafe (1.0)
pip (9.0.1)
pyang (1.6)
Pygments (2.2.0)
pytz (2017.2)
rstr (2.2.6)
setuptools (36.2.7)
six (1.10.0)
smmap (0.9.0)
snowballstemmer (1.2.1)
Sphinx (1.4a1)
sphinx-rtd-theme (0.1.9)
wheel (0.29.0)
I can generate the CORE with /generate.py --python --core
But when I want to install it, it fails:
(py2) rob@ubuntu:ydk-gen$ pip install gen-api/python/ydk/dist/ydk*.tar.gz
Processing ./gen-api/python/ydk/dist/ydk-0.6.0.tar.gz
Collecting pybind11>=2.1.1 (from ydk==0.6.0)
  Using cached pybind11-2.1.1-py2.py3-none-any.whl
Building wheels for collected packages: ydk
[b]  Running setup.py bdist_wheel for ydk ... error[/b]
  Complete output from command /home/rob/.virtualenvs/py2/bin/python2.7 -u -c "import setuptools, tokenize;__file__='/tmp/pip-W4OeBF-build/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/tmpWKtY0Ypip-wheel- --python-tag cp27:
  running bdist_wheel
  running build
  running build_py
  creating build
  creating build/lib.linux-x86_64-2.7
  creating build/lib.linux-x86_64-2.7/ydk
  copying ydk/__init__.py -> build/lib.linux-x86_64-2.7/ydk
  copying ydk/exthook.py -> build/lib.linux-x86_64-2.7/ydk
  creating build/lib.linux-x86_64-2.7/ydk/services
  copying ydk/services/__init__.py -> build/lib.linux-x86_64-2.7/ydk/services
  copying ydk/services/codec_service.py -> build/lib.linux-x86_64-2.7/ydk/services
  copying ydk/services/executor_service.py -> build/lib.linux-x86_64-2.7/ydk/services
  copying ydk/services/netconf_service.py -> build/lib.linux-x86_64-2.7/ydk/services
  copying ydk/services/crud_service.py -> build/lib.linux-x86_64-2.7/ydk/services
  creating build/lib.linux-x86_64-2.7/ydk/ext
  copying ydk/ext/__init__.py -> build/lib.linux-x86_64-2.7/ydk/ext
  creating build/lib.linux-x86_64-2.7/ydk/errors
  copying ydk/errors/__init__.py -> build/lib.linux-x86_64-2.7/ydk/errors
  copying ydk/errors/error_handler.py -> build/lib.linux-x86_64-2.7/ydk/errors
  creating build/lib.linux-x86_64-2.7/ydk/logging
  copying ydk/logging/__init__.py -> build/lib.linux-x86_64-2.7/ydk/logging
  creating build/lib.linux-x86_64-2.7/ydk/types
  copying ydk/types/__init__.py -> build/lib.linux-x86_64-2.7/ydk/types
  copying ydk/types/py_types.py -> build/lib.linux-x86_64-2.7/ydk/types
  creating build/lib.linux-x86_64-2.7/ydk/filters
  copying ydk/filters/__init__.py -> build/lib.linux-x86_64-2.7/ydk/filters
  creating build/lib.linux-x86_64-2.7/ydk/models
  copying ydk/models/__init__.py -> build/lib.linux-x86_64-2.7/ydk/models
  creating build/lib.linux-x86_64-2.7/ydk/entity_utils
  copying ydk/entity_utils/__init__.py -> build/lib.linux-x86_64-2.7/ydk/entity_utils
  creating build/lib.linux-x86_64-2.7/ydk/providers
  copying ydk/providers/__init__.py -> build/lib.linux-x86_64-2.7/ydk/providers
  copying ydk/providers/codec_provider.py -> build/lib.linux-x86_64-2.7/ydk/providers
  creating build/lib.linux-x86_64-2.7/ydk/path
  copying ydk/path/__init__.py -> build/lib.linux-x86_64-2.7/ydk/path
  creating build/lib.linux-x86_64-2.7/ydk/path/sessions
  copying ydk/path/sessions/__init__.py -> build/lib.linux-x86_64-2.7/ydk/path/sessions
  copying ydk/path/sessions/netconf_session.py -> build/lib.linux-x86_64-2.7/ydk/path/sessions
  copying ydk/path/sessions/restconf_session.py -> build/lib.linux-x86_64-2.7/ydk/path/sessions
  running build_ext
  Installing collected packages: pybind11
  Successfully installed pybind11-2.1.1
  -- The C compiler identification is GNU 5.4.0
  -- The CXX compiler identification is GNU 5.4.0
  -- Check for working C compiler: /usr/bin/cc
  -- Check for working C compiler: /usr/bin/cc -- works
  -- Detecting C compiler ABI info
  -- Detecting C compiler ABI info - done
  -- Detecting C compile features
  -- Detecting C compile features - done
  -- Check for working CXX compiler: /usr/bin/c++
  -- Check for working CXX compiler: /usr/bin/c++ -- works
  -- Detecting CXX compiler ABI info
  -- Detecting CXX compiler ABI info - done
  -- Detecting CXX compile features
  -- Detecting CXX compile features - done
  python library: /usr/lib/python2.7/config-x86_64-linux-gnu/libpython2.7.so
  python include: /usr/include/python2.7
  pybind11 include: /home/rob/.virtualenvs/py2/include/site/python2.7;/home/rob/.virtualenvs/py2/include/site/python2.7
  -- Configuring done
  -- Generating done
  -- Build files have been written to: /tmp/pip-W4OeBF-build/build/temp.linux-x86_64-2.7
  Scanning dependencies of target ydk_
  [ 50%] Building CXX object CMakeFiles/ydk_.dir/python.cpp.o
  /tmp/pip-W4OeBF-build/python.cpp:22:35: fatal error: ydk/restconf_client.hpp: No such file or directory
  compilation terminated.
  CMakeFiles/ydk_.dir/build.make:62: recipe for target 'CMakeFiles/ydk_.dir/python.cpp.o' failed
  make[2]: *** [CMakeFiles/ydk_.dir/python.cpp.o] Error 1
  CMakeFiles/Makefile2:67: recipe for target 'CMakeFiles/ydk_.dir/all' failed
  make[1]: *** [CMakeFiles/ydk_.dir/all] Error 2
  Makefile:83: recipe for target 'all' failed
  make: *** [all] Error 2
  Traceback (most recent call last):
    File "<string>", line 1, in <module>
    File "/tmp/pip-W4OeBF-build/setup.py", line 157, in <module>
      zip_safe=False,
    File "/usr/lib/python2.7/distutils/core.py", line 151, in setup
      dist.run_commands()
    File "/usr/lib/python2.7/distutils/dist.py", line 953, in run_commands
      self.run_command(cmd)
    File "/usr/lib/python2.7/distutils/dist.py", line 972, in run_command
      cmd_obj.run()
    File "/home/rob/.virtualenvs/py2/local/lib/python2.7/site-packages/wheel/bdist_wheel.py", line 179, in run
      self.run_command('build')
    File "/usr/lib/python2.7/distutils/cmd.py", line 326, in run_command
      self.distribution.run_command(command)
      cmd_obj.run()
    File "/usr/lib/python2.7/distutils/command/build.py", line 128, in run
      self.run_command(cmd_name)
      cmd_obj.run()
    File "/tmp/pip-W4OeBF-build/setup.py", line 69, in run
      self.build_extension(ext)
    File "/tmp/pip-W4OeBF-build/setup.py", line 94, in build_extension
      subprocess.check_call(['cmake', '--build', '.'], cwd=self.build_temp)
    File "/usr/lib/python2.7/subprocess.py", line 541, in check_call
      raise CalledProcessError(retcode, cmd)
  subprocess.CalledProcessError: Command '['cmake', '--build', '.']' returned non-zero exit status 2
  Failed building wheel for ydk
  Running setup.py clean for ydk
Failed to build ydk
Installing collected packages: pybind11, ydk
  Running setup.py install for ydk ... error
    Complete output from command /home/rob/.virtualenvs/py2/bin/python2.7 -u -c "import setuptools, tokenize;__file__='/tmp/pip-W4OeBF-build/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-jD4xpB-record/install-record.txt --single-version-externally-managed --compile --install-headers /home/rob/.virtualenvs/py2/include/site/python2.7/ydk:
    running install
    running build
    running build_py
    creating build
    running build_ext
    -- Configuring done
    -- Generating done
        zip_safe=False,
        dist.run_commands()
        cmd_obj.run()
      File "/home/rob/.virtualenvs/py2/local/lib/python2.7/site-packages/setuptools/command/install.py", line 61, in run
        return orig.install.run(self)
      File "/usr/lib/python2.7/distutils/command/install.py", line 601, in run
        cmd_obj.run()
        cmd_obj.run()
[b]Command "/home/rob/.virtualenvs/py2/bin/python2.7 -u -c "import setuptools, tokenize;__file__='/tmp/pip-W4OeBF-build/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-jD4xpB-record/install-record.txt --single-version-externally-managed --compile --install-headers /home/rob/.virtualenvs/py2/include/site/python2.7/ydk" failed with error code 1 in /tmp/pip-W4OeBF-build/[/b]
16 Replies 16
sanshety
Unable to install gdebi libydk_0.6.2-1_amd64.deb
   I am getting following error:
# gdebi libydk_0.6.2-1_amd64.deb
Reading package lists... Done
Building dependency tree
Reading state information... Done
This package is uninstallable
Dependency is not satisfiable: cmake (>= 3)
I have cmake installed :
# cmake --version
cmake version 3.4.1
CMake suite maintained and supported by Kitware (kitware.com/cmake).
Can you let me know the operating system you are using?
Please make sure to install all the dependencies as done in this script for ubuntu:
ydk-py/dependencies_xenial.sh at master · CiscoDevNet/ydk-py · GitHub
